What offset for 15 x 7.5" ??
Old Apr 6, 2005 | 01:48 PM
ITRpwrdEG's Avatar
Default What offset for 15 x 7.5" ??
I plan on getting the Work Equip 03 wheels for my 00SI but want to get the 7.5" over the 7". I figure if i'm gonna spend that much I might as well get some serious LIP action. What do you guys recommend for an offset or a range of offsets that will let it work with a 96-00 Civic. I plan on putting 205 series tires to help a little bit tuck under the wells but also some negative camber once the car is cornerweighted with Tein Flex's too.
35mm?
38mm?
or what?
Old Apr 7, 2005 | 12:57 PM
slwboostedDC2's Avatar
Default Re: What offset for 15 x 7.5" ?? (ITRpwrdEG)
use a 38 offset as your car doesn't allow for much wheel play under the fender.
Old Apr 8, 2005 | 12:41 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: What offset for 15 x 7.5" ?? (slwboostedDC2)
get 43........
i had ssr comps 15x7.5 with azenis 205 50's......
they fit perfect
Old Apr 8, 2005 | 08:35 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: What offset for 15 x 7.5" ?? (SnoFlake y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake y0 &raquo;</TD></TR><TR><TD CLASS="quote">get 43........
they fit perfect</TD></TR></TABLE>
why have the extra weight of the 7.5 width and not take advantage of the real estate for a wider tyre. a 205 will fit fine even on a 6.5 width.
stan
Old Apr 8, 2005 | 11:09 AM
ITRpwrdEG's Avatar
Default Re: What offset for 15 x 7.5" ?? (Stan D)
you wanna know why? because some people want that stretched look with the tire around the rim so if someone was to put a 195 on a 7" wide wheel then they are already downgrading to a smaller tire with less performance for the street. So if you go with a 7.5" wide wheel then you can fit the exact same tire that you orginally had on a popular 7" wheel. You get the same performance, but you can see the lip more with the stretched effect. When you go with old school wheels such as Work, BBS, Blitz 01, SSR reverse mesh, then you want that effect. As least, that's the effect I want.
I ordered (2) 15 x 7.5" 42mm offset and (2) 15 x 7.5" 44mm offset. thanks for the help guys.
Old Apr 8, 2005 | 11:32 AM
i doubt you will have any lip on a 42mm offset wheel...
stan
Old Apr 8, 2005 | 03:26 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
thats them right there about 2 fingers worth of lip maybe a lil more....ill see if i have a better angle
Old Apr 9, 2005 | 07:25 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">
stan</TD></TR></TABLE>
Azenis are not your typical 205.. They feel like garbage on anything less than 7" wheel. Response and turn-in is horrible.
Old Apr 18, 2005 | 10:14 AM
ITRpwrdEG's Avatar
Default Re: What offset for 15 x 7.5" ?? (FunctionMotoring)
Stan,
I bet I will get some lip with the offset I chose because Work helped me pick it.
42mm offset = 1.25" lip (fronts)
44mm offset = 1.8" lip (rears)
biggest lips you can go on a Honda Civic without crazy modification or rolling of the fenders.
Old Apr 23, 2005 | 09:38 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRpwrdEG &raquo;</TD></TR><TR><TD CLASS="quote">Stan,
biggest lips you can go on a Honda Civic without crazy modification or rolling of the fenders. </TD></TR></TABLE>
mine were rolled!!!!!
Ultraspeed DC2
Sep 1, 2008 11:38 AM
grey_ghost
Jan 21, 2008 08:57 AM
racer22
Mar 6, 2007 10:30 PM
FrostyDC4
Oct 1, 2004 05:40 PM
Mr.Saturn
Nov 9, 2003 08:51 PM
