H23 vs. H22
Old Apr 6, 2005 | 01:38 PM
Corruption's Avatar
Default H23 vs. H22
I was wondering what the pros and cons are of both engines. They're relatively the same thing, however one is a bit cheaper than the other...that being the H22 but the H23 comes in Euro Accords 98+. I might consider one of these engines in the future for my 01' Accord. thanks
Old Apr 8, 2005 | 04:21 PM
h22_cx_hatch's Avatar
Default Re: H23 vs. H22 (Corruption)
h22= lots of power but hardest motor to swap
h23= i dont know much...............................
choose. use the force to guide you...............
Old Apr 8, 2005 | 07:54 PM
billybob's Avatar
h22 for sure the h23 only has 160 hp while the h22 has from 190-220 hp and around a 150 ft lbs
Old Apr 8, 2005 | 08:26 PM
H_doubledeuce_A1's Avatar
Default Re: H23 vs. H22 (billybob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what the pros and cons are of both engines. They're relatively the same thing, however one is a bit cheaper than the other...that being the H22 but the H23 comes in Euro Accords 98+. I might consider one of these engines in the future for my 01' Accord. thanks</TD></TR></TABLE>
R u talking about the JDM H23a1 Vtec model out of the Accord Wagon or the plan jane H23a non-vtec?
Old Apr 9, 2005 | 08:21 AM
-Darren-'s Avatar
h22 is the answer if you want vtec and 190-220hp stock
h23 is the 160hp non vtec
Old Apr 9, 2005 | 11:57 AM
GZERO's Avatar
Default Re: H23 vs. H22 (-Darren-)
guys i think he meant the H23A VTEC, the one the guy above mentioned, the H23A has more torque and better power band, but it comes at a price, and IMHO a very expensive one.....
Old Apr 9, 2005 | 02:48 PM
-Darren-'s Avatar
Default Re: H23 vs. H22 (GZERO)
damn, never knew there was a such thing as a h23 w/vtec, now i know
Old Apr 9, 2005 | 04:09 PM
Corruption's Avatar
Darren, I'm already aware of the engine specs. on both engines. I was wondering about things such as the quality comparison, sleeves and internals, reliability, and the performance orientation of both. Basically just want to see if the H23a would be less of a hassle to swap in my 6th gen accord than a H22, since an H23 is a European based accord engine...
Old Apr 9, 2005 | 05:28 PM
-Darren-'s Avatar
Default Re: (Corruption)
oh ok. i would assume the one that came in the euro accord would be easier.
anyways bump for you hopefully you'll get a good answer. have you tried the hybrid or accord forums?
Old Apr 9, 2005 | 05:48 PM
jackstands's Avatar
Default Re: (-Darren-)
same block, same liners. same electronics. same mounts. h23avtec more expensive for not much more power.
Old Apr 10, 2005 | 08:02 AM
Corruption's Avatar
thanks jack, however would the h23 swap be an easier swap than an h22 into a 6th gen?
Old Apr 10, 2005 | 10:02 AM
-Darren-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption &raquo;</TD></TR><TR><TD CLASS="quote">thanks jack, however would the h23 swap be an easier swap than an h22 into a 6th gen?</TD></TR></TABLE>
we he did say:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackstands &raquo;</TD></TR><TR><TD CLASS="quote">same block, same liners. same electronics. same mounts. h23avtec more expensive for not much more power. </TD></TR></TABLE>
but hopefully someone answer's your question a bit better.
asmallsol
Aug 23, 2006 03:58 AM
Silencer RPMs
Feb 17, 2005 02:15 AM
SAVIOVEGA
Jul 31, 2004 04:36 PM
trev4
Jul 21, 2004 10:25 AM
