clutch gurus, help me out
Old Apr 6, 2005 | 01:04 PM
743power's Avatar
Default clutch gurus, help me out
The last two clutches I have replaced were oem b-series clutches. They both had the same symptoms prior to replacement and both had the EXACT same problem when removed. Here are the pics of mine, which i pulled today:
the mashed up spring is actually next to this one
Has anyone seen this before? Is this something caused by a weak point or design flaw, or driver error (neither cars were drag raced or misshifted/forced into gear)
Modified by 743power at 11:01 PM 4/6/2005
Old Apr 6, 2005 | 07:03 PM
743power's Avatar
Default Re: clutch gurus, help me out (743power)
bump for honda-TECH
I am not too concerned with this, I have another clutch waiting to go in. Just curious that's all.
only thing left on my front end is the block.
Old Apr 6, 2005 | 08:52 PM
Jim Truett's Avatar
This is generally caused by hard shifting.It's not so much that it is being slammed into gear, it's because of a significant difference in crank rpm compared to trans input shaft rpm at the time of clutch engagement. Get a stronger clutch, or don't drive it so hard.
Old Apr 6, 2005 | 10:41 PM
Kendall's Avatar
Learn to heel/toe and revmatch when downshifting and you're likely to never see this problem again.
Old Apr 7, 2005 | 04:19 AM
743power's Avatar
Default Re: (Kendall)
Like I said, the car wasn't raced or anything like that. Spirited driving at worst. Clutch probably has about 150k miles on it.
Old Apr 7, 2005 | 07:07 AM
mmuller's Avatar
Mad Scientist
Default Re: (743power)
i have seen high mileage stock clutches look like that
Old Apr 7, 2005 | 10:33 AM
jdmitr's Avatar
Default Re: (mmuller)
Stock clutch discs suck!!! I have had seen about a dozen do this!!! If you cannot afford a new clutch kit, just order the organic disc from ACT by itself It holds up great!), and get your flywheel resurfaced! Cheap alternative and an excellent set up!!!!!
Old Apr 7, 2005 | 05:55 PM
jackstands's Avatar
Default Re: (jdmitr)
150k is a lot for a stock clutch.
Old Apr 7, 2005 | 06:08 PM
743power's Avatar
Default Re: (jackstands)
its funny because as soon as my clutch crapped out I knew EXACTLY what I was going to find when I pulled the trans.
Old Apr 7, 2005 | 06:11 PM
JDMHN8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr &raquo;</TD></TR><TR><TD CLASS="quote">Stock clutch discs suck!!!</TD></TR></TABLE>
There is absolutely nothing wrong with a stock disk or pressure plate. My 125K stock clutch had seen numerouse track events, strip passes and some light ricer burn outs and still was in one piece. I swapped it out for a low mileage ITR clutch setup that works really well w/o a heavy pedal or arsh engagement. I can't see a real reason to go with anything more than an Exedy Organic for a daily driven car &gt;220 HP....
misoshiru_akira
Mar 7, 2007 09:20 AM
Weston
Jun 15, 2006 07:37 PM
MJobe
Feb 9, 2006 06:04 AM
alfaaay
Mar 31, 2003 11:57 AM
onyx00
Sep 20, 2002 10:06 AM
