compression test on a cold engine
Old Apr 6, 2005 | 10:44 AM
aalb1's Avatar
Default compression test on a cold engine
I want to do a compression test on my engine but it won't start. What drawbacks are there when doing a compression test on a cold engine. Is there anything I should watch out for?
Old Apr 6, 2005 | 11:55 AM
PrettyLude's Avatar
inacurrate readings
Old Apr 6, 2005 | 09:10 PM
Phase Change Racing's Avatar
Default Re: compression test on a cold engine (aalb1)
You will usually get a lower reading with a cold engine. If it has not run in a while you may have an issue with some of your rings sticking and giving you really low comp readings. Spray a little brakekleen (two seconds worth or so) in each cyl, crank it over until the cyls dry out, pour a tablespoon or two of engine oil in the cyls, crank again, and you should be able to get a pretty good comp reading
If your car won't start and you are thinking it might be a compression issue pretty much anything in the tripple digit range will fire an air/fuel mixture.
r.etheridge
Feb 12, 2011 05:31 PM
skaternak
10
Aug 9, 2009 05:48 PM
honda_prelude_jay
Jan 3, 2009 03:36 PM
spidermancivic
Jul 13, 2005 07:53 PM
98R-1144
Jan 6, 2003 09:50 PM
