Bad O2 Sensor
I have to vent! So my check engine Light came on last week.. I decided to drop my car off at the Dealer...
Well it turn out that the Rear O2 Sensor is bad and need to be replaced. They said $450 for parts and installation!
I was like WTF are you crazy....I said NO park my car outside I'll be there soon to pick it up.
I just ordered a Rear O2 from Len ....Is replacing the Rear O2 a complicated thing to do? Can anyone shed some light as to what is involved
Thanks
Thanks
You'll have to pull the entire cat off to get the o2 sensor removed. Have plenty of WD40 or PB Blaster on hand, as well as an o2 sensor socket.
That **** will be more corroded and crusty than an 87-year old prostitute's poontang.
Undo the front bolts on the cat and let the cat/bpipe hang, that should give you enough room to take out the O2 sensor... You might have to slip off the rubber hangers in the middle of the car.
CivicExMaster
25
Oct 15, 2008 07:16 PM
dwf2096
May 12, 2008 03:56 PM
