hondata 7.5-8.5 psi dynoed on friday.
Old Jan 28, 2002 | 09:22 AM
salt's Avatar
Default hondata 7.5-8.5 psi dynoed on friday.
what happens at 6500 RPM ? usually it seems like they make more
at that point not less. I'll look at the datalog later and see if I see anything.
This was done on a mustang dyno which usually rates lower than a
dynojet for some reason.
B18C5,JRSC, stepper pulley,440RC,kamakazi,160' stat...
Old Jan 28, 2002 | 09:23 AM
sgT's Avatar
sgT
Default Re: hondata 7.5-8.5 psi dynoed on friday. (salt)
That is a GOOD graph. Nice FLAT torque curve.
Couldnt ask for more.
Old Jan 28, 2002 | 09:28 AM
DR. ON POINT's Avatar
Banned
Default Re: hondata 7.5-8.5 psi dynoed on friday. (sgT)
thats good man
proton's Avatar
No kidding. That is a great looking torque curve!
Old Jan 28, 2002 | 09:34 AM
VTC_CiViC's Avatar
Default Re: hondata 7.5-8.5 psi dynoed on friday. (proton)
That's not a curve, it's a damn line!!! Very nice
Old Jan 28, 2002 | 09:45 AM
austrian type-R's Avatar
Default Re: hondata 7.5-8.5 psi dynoed on friday. (VTC_CiViC)
you have my props!
Old Jan 28, 2002 | 09:47 AM
TurboSedan's Avatar
New User
Default Re: hondata 7.5-8.5 psi dynoed on friday. (austrian ITR)
Awesome broad torque curve!!!
Old Jan 28, 2002 | 09:48 AM
VaporTrail's Avatar
New User
Default Re: hondata 7.5-8.5 psi dynoed on friday. (97CivicFerio)
nice work, looks great!
Old Jan 28, 2002 | 09:50 AM
Do you have some dataalog? Where is the timing set at? How high is the intake air temp?
I had blown my motor after I installed the stepper pulley. My cr is (was) JDM spec 11.1:1 and boost showed 8.5psi. After 0.5 hours on the dyno (with wide band O2 sensor + Haltech e6k standalone) #4 had zero compression. fug -> now rebuilt for turbo
[Modified by austrian ITR, 10:50 AM 1/28/2002]
chri5's Avatar
Are you sure you didnt just draw that with a ruler?
Old Jan 28, 2002 | 10:01 AM
threatcon13's Avatar
New User
Default Re: hondata 7.5-8.5 psi dynoed on friday. (Strng1dah)
nice!
Old Jan 28, 2002 | 10:04 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: hondata 7.5-8.5 psi dynoed on friday. (turbo01gsr)
WOW!!
Old Jan 28, 2002 | 10:19 AM
salt's Avatar
thanks for the positive comments, I've migrated here from all the other 'down' boards, SHO,hostboard,TOO...
I've got to thank Holden for his install web site, and austrian ITR for having a
similar setup. I know the 8.5 is kinda high for my JDM type r motor, but I'm hoping
the hondata will prove cost effective.
I can post the datalog if anyone wants, you can DL the viewer
Im not sure on the air intake temp, I havent looked at the log yet
Steve
Old Jan 28, 2002 | 11:20 AM
DIRep972's Avatar
Smarter than you
very nice.. what is a mustang dyno?
Old Jan 28, 2002 | 11:37 AM
DA666's Avatar
Default Re: hondata 7.5-8.5 psi dynoed on friday. (DIRep972)
nice nice....how hard is the data logger to tune with for the first time? like if u just installed and are starting to tune...or did u not tune it urself?
Old Jan 28, 2002 | 11:40 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: hondata 7.5-8.5 psi dynoed on friday. (T3T4DA6)
Mustang Dyno is a different company that makes dynos. There is one here in dallas Cobbs tunning that does the AWD wrx's. Other companys that makes dynos:
Mustang
DynoJet
Dynapack
Bosch..
art
Old Jan 28, 2002 | 12:13 PM
Salt: you have 11.1:1 compression? Usualy the USDM ITR spec engine (B18C5) only has 10.6:1. Common` don´t tell me you have 11.1:1 cr
BTW: What exhaust setup fo you have? I only read Kami header. I think you should upgrade to some 3incher when you have not already.
[Modified by austrian ITR, 1:14 PM 1/28/2002]
[Modified by austrian ITR, 1:16 PM 1/28/2002]
Old Jan 28, 2002 | 12:20 PM
lucas569's Avatar
omg how long did it take to get a curve like that?! thats very sweet,must feel like an electric rc car
Old Jan 28, 2002 | 01:41 PM
salt's Avatar
I have a 1997 JDM B18C r spec, I don't know the real CR, but I'm guessing its
11:1
The exhuast is the kami 2.5 collector, test pipe, greddy cat back. My exhaust is
already loud enough for me. I don't think I could handle a 3"
Old Jan 28, 2002 | 02:13 PM
CKim's Avatar
Hey Salt... nice numbers.
I too am over here from hostboard because the board is down.
Old Jan 28, 2002 | 03:16 PM
miller's Avatar
Default Re: hondata 7.5-8.5 psi dynoed on friday. (CKim)
deffinatley nice!!
Old Jan 28, 2002 | 03:22 PM
LsTurbo91's Avatar
lets see the datalogs! nice
Old Jan 28, 2002 | 04:20 PM
SenekaGSR's Avatar
Default Re: hondata 7.5-8.5 psi dynoed on friday. (LsTurbo91)
very nice!
Old Jan 28, 2002 | 06:15 PM
freakie's Avatar
Default Re: hondata 7.5-8.5 psi dynoed on friday. (SenekaGSR)
Salt, have you decreased the CR of your motor in anyway?
I always thought that 11 to 1 CR was way too high for boost. Not only that but you are boosting 8.5 psi!!!!
pls tell me that that motor is not stock!!1
Old Jan 28, 2002 | 08:51 PM
TurboTegB18c's Avatar
Damn, nice torque curve.
