Suspension & Brakes Theory, alignment, spring rates....
99-00 Suspension on a EG CX
Old Apr 6, 2005 | 04:36 AM
THEUSED's Avatar
Default 99-00 Suspension on a EG CX
Im about to pick up some 99 SI suspension for a really good price, the suspension should just bolt right on and work..... right, besides having to convert the rears to disks?
For anyone whos done this how were the results?
Also I tried searching, SI is not your best word to search
Old Apr 6, 2005 | 05:12 AM
Smashback's Avatar
Default Re: 99-00 Suspension on a EG CX (THEUSED)
No, Integra DC suspension is compatible with yours. 96-00 and 99-00 Civic susp. may bolt up but it's not the same.
Old Apr 6, 2005 | 07:26 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: 99-00 Suspension on a EG CX (Smashback)
The 99-00 Si front sway bar will ONLY work if you use the matching 99-00 Si LCAs & end-links. The rear LCAs & shocks will NOT work. 96-00 Civic LCAs are about an inch longer than the EG/DC LCAs. They are also skinnier, so the EK shocks lower mount won't fit over the EG LCA bushings.
The rear discs/trailing arms will work fine, but you will need a 90-00 NON ABS integra proportioning valve. 92-95 NON ABS Si, or 93-97 NON ABS/Rear Disc Del sol prop valve will work too (and mabey 90-91 CRX Si).
I don't know if your getting the e-brake cables or not, but you should get ones from a 92-95 Si, or any 2dr 94+ integra.
If your adding the 10.2" front brakes to your CX, you also need a 7/8" master cylinder. You can get one for the 93-95 EX 2dr (NON ABS). It is a perfect match for those brakes, and will bolt directly to your stock brake booster...
Old Apr 6, 2005 | 02:16 PM
THEUSED's Avatar
Im just getting the complete brakes, the guy got 5Lug suspension so everything that he'd need to change I should be getting,
the setup was on a DC
So the Front Disks wont work?
Old Apr 6, 2005 | 02:28 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">So the Front Disks wont work?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">If your adding the 10.2" front brakes to your CX, you also need a 7/8" master cylinder. You can get one for the 93-95 EX 2dr (NON ABS). It is a perfect match for those brakes, and will bolt directly to your stock brake booster...</TD></TR></TABLE>
Old Apr 6, 2005 | 02:59 PM
THEUSED's Avatar
Sorry about that there's alot of numbers and letters
Thanks alot
Old Apr 6, 2005 | 05:33 PM
Targa250R's Avatar
be professional
Default Re: 99-00 Suspension on a EG CX (94eg!)
The '93-95 EX non-ABS coupe had a 13/16" MC.
Old Apr 6, 2005 | 07:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: 99-00 Suspension on a EG CX (Targa250R)
***edit***
Modified by 94eg! at 8:31 AM 4/25/2005
Old Apr 6, 2005 | 11:41 PM
DynamicCK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">Im about to pick up some 99 SI suspension for a really good price, the suspension should just bolt right on and work..... right, besides having to convert the rears to disks?
Also I tried searching, SI is not your best word to search </TD></TR></TABLE>
works fine, just use the trailing arms from the EK but keep your stock LCA. And get an EG SI ebrake cable or if you can get the EK ebrake cable. Also, if your using the shocks and springs, you should press your LCA bushings out to Prothane, or energy suspension.
Old Apr 7, 2005 | 03:19 AM
THEUSED's Avatar
Thanks Guys, Im getting the Ebrake Cables aswell, all for 250, I figure this is a good price......
Old Apr 24, 2005 | 12:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
The '93-95 EX non-ABS coupe had a 13/16" MC.</TD></TR></TABLE>
To 94eg!, I'd like to apologize and make a correction. The '93-95 EX non-ABS coupe did indeed have a 7/8" master cylinder as you originally stated. My mistake.
AMS PARTS
Jul 19, 2010 02:34 PM
showgun
Jul 7, 2005 03:00 PM
vbphreak
Mar 16, 2005 06:13 AM
Ehron
Feb 16, 2004 11:08 AM
johnny hatchback
May 29, 2003 03:21 PM
