Car Willnt Start HELP
Old Apr 6, 2005 | 03:18 AM
BuCxLuXoRX2o0o's Avatar
Default Car Willnt Start HELP
my check engine light came on and i tired to check it to see what it was. i found on a different forum to jump #4 and #9 on the OBDII connector pinout and turn the engine to ON. and count the flashes. well stupid me jumped #4 and #16 because it was upside down and the 6 looked like a 9, so after i did that it sparked for a sec. then i connected it correctly and tried to pull the code again, but the check engine didnt light up anymore. so i tried to start the car and it would crank but not turn over. no check engine light at all, normally it would turn on and go off but nothing at all now. is this information correct?
pin 4 = chassis ground
pin 5 = signal ground from ECU pin E3
pin 7 = K-line (2-way OBDII comms line) to ECU pin E23
pin 9 = SCS line to ECU pin E29
pin 12 = write-enable signal to ECU pin E30
pin 14 = +5 V
pin 16 = +12 V battery voltage
what should i be checking for? btw i have a 2000 accord lx
Modified by BuCxLuXoRX2o0o at 7:28 AM 4/6/2005
Old Apr 6, 2005 | 05:08 AM
JimBlake's Avatar
Default Re: Car Willnt Start HELP (BuCxLuXoRX2o0o)
Looks like you jumpered directly from battery to ground, so look for blown fuses. Maybe that pin 16 shares a fuse with the ECU power? On a 6th-gen Accord I think you have 3 fuseboxes to check - under hood & both ends of the dashboard.
Old Apr 6, 2005 | 05:33 AM
Default Re: Car Willnt Start HELP (JimBlake)
thanks for the quick reply...from what i read there is no fuse in between the obd connector and the ECU. so with that being said i hope i didnt fry the ECU. here is a direct quote
" There are actually 3 or 4 variants of the OBDII "standard" but Honda uses ISO 9141. The reason you want to be a bit careful when probing the OBDII connector is that the pins run directly to the ECU (no fuse in between), and like you said, there are different voltages and grounds in there."
Old Apr 6, 2005 | 11:32 AM
anybody else care to give their $.02 on this matter?
Old Apr 6, 2005 | 12:43 PM
matt_in_sd's Avatar
Check fuse 46 in the underhood fuse box. Pin 16 gets power from there.
Old Apr 6, 2005 | 03:53 PM
Default Re: Car Willnt Start HELP (matt_in_sd)
BINGO that was what it was. my car runs like a champ now. thanks for the help matt
Old Apr 6, 2005 | 05:13 PM
"Willn't"?...
LMFAO! im sorry, but thats just hilarious to me!
dojo19xx
Honda S2000
Oct 21, 2011 10:46 AM
88crx Osaka
Aug 20, 2011 10:42 PM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
tougetuned_ef
Jun 13, 2006 05:39 PM
EF-21
Mar 16, 2004 09:45 PM
