questions on drysump and what valves?
hello. i am building a stroked gsr. i was planning on what valves i should run with. over all compression i want is 12.5
heres the list
gsr p72 head going to rlz to do valve job and port and polish
rocket valve springs
rocket retainers
jun3 cams
type r lmas
itbs done by me with gsxr 750s or hayabusas, not sure yet, if i get the hayabusas,
i will do that
dtr fab header once its all done
scat 95mm crank .75 deck plate approximately
85 mm bore
pistons yet to be determined by erl
rods " "
ati damper
z10 dry sump
so what valves should i run? i am not sure. havent had a chance to call brad up and talk to him either. so trying to get some inputs before i order all my parts and send to him. also another question. anybody think dry sump is fine for daily driving?
heres the list
rocket retainers
jun3 cams
type r lmas
i will do that
85 mm bore
rods " "
ati damper
z10 dry sump
You need to ask your porter which valves he recommends with his port work.The shape of the valve affects flow.The stock valves have a great shape but every one has their preference.He may also recommend a size change in the valve.Take the time to make the call.A drysump should be fine for a daily driver.
Glenn
Glenn
