h22 eg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morf »</TD></TR><TR><TD CLASS="quote">im puting a h22 in my eg would i have to strenthan the front end or not
Alright i want you to step back and put down the crack pipe. Pull your head out of your *** and look up at the very top post in this forum. I know it might be a little hard to believe but if you just read before you start posting useless questions that have been covered a million times you might will find your answer.
Now if your too dumb to figure out that paragraph out just click this and read......
https://honda-tech.com/zerothread?id=650329
</TD></TR></TABLE>Alright i want you to step back and put down the crack pipe. Pull your head out of your *** and look up at the very top post in this forum. I know it might be a little hard to believe but if you just read before you start posting useless questions that have been covered a million times you might will find your answer.
</TD></TR></TABLE>yes, you need to weld @ least 4 crossbars from one frame rail to the next. I suggest you use 2x4's grade 8 boards and some self tapping screws and lots of JB weld. I would also remove the bumper support and jam another 2x4 between the frame rail then glue it in place with Elmers glue. As far as suspension I would use the springs from a F-150 to hold the extra 300lb extra from the H22. Last but not least I would remove the old mounts and weld the motor and trans permanently to the chassis, that would "strethan" the front end.
J/K....... you just need a good suspension.
</TD></TR></TABLE>yes, you need to weld @ least 4 crossbars from one frame rail to the next. I suggest you use 2x4's grade 8 boards and some self tapping screws and lots of JB weld. I would also remove the bumper support and jam another 2x4 between the frame rail then glue it in place with Elmers glue. As far as suspension I would use the springs from a F-150 to hold the extra 300lb extra from the H22. Last but not least I would remove the old mounts and weld the motor and trans permanently to the chassis, that would "strethan" the front end.J/K....... you just need a good suspension.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben1818 »</TD></TR><TR><TD CLASS="quote">no you dont have to weld i have costume mounts from a guy that did it and he never welded</TD></TR></TABLE>yes you do.
You have costume mounts? What do they dress up as, Batman and Robin?
i didn't have to weld to drop mine in. a lot of cutting + drilling though. but i didn't have costume mounts either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UpstateCivic »</TD></TR><TR><TD CLASS="quote">
Even batman and robin can't hold the H's torque.
</TD></TR></TABLE>Even batman and robin can't hold the H's torque.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morf »</TD></TR><TR><TD CLASS="quote">wich is the best type of glue
wood
or super glue
lolololol</TD></TR></TABLE>
losing patience with this one.
hey morf: get a b16. its a better motor anyway
wood
or super glue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer »</TD></TR><TR><TD CLASS="quote">hey morf: get a b16. its a better motor anyway</TD></TR></TABLE>
WRONG. Morf, do a d15b7, much better motor, 200hp stock...............its jdm too yo. Comes with lots of stickers too.
hey morf: get a b16. its a better motor anyway</TD></TR></TABLE>WeRd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">I braced my entire front end with VTEC decals. Holds up well
yeah, but if you spell it VTECH then it will hold up alot better. That extra letter makes all the difference. Besides VTECH or VTEC it's still a Vtak!
</TD></TR></TABLE>yeah, but if you spell it VTECH then it will hold up alot better. That extra letter makes all the difference. Besides VTECH or VTEC it's still a Vtak!
Just get a decent suspension setup, and also I seen that a company called Korbach came up with something called "frame locks" for a 96-00 civic.
Check it out: https://honda-tech.com/zerothread?id=997376
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone »</TD></TR><TR><TD CLASS="quote">Just get a decent suspension setup, and also I seen that a company called Korbach came up with something called "frame locks" for a 96-00 civic.
</TD></TR></TABLE>did you not read the post? he said EG.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky »</TD></TR><TR><TD CLASS="quote">
If you spell it VTECH, you get stickers and a crappy cordless phone.
Now for the tech part, just focus a little on suspension and you'll be fine. Actually it's one of the first mods I did with my h22 swap. Can't wait to get my car running again. Boost is good!
</TD></TR></TABLE>If you spell it VTECH, you get stickers and a crappy cordless phone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer »</TD></TR><TR><TD CLASS="quote">sixgundone: no need to try to give valid responses. apparently this guy morf refuses to read the stickies or search. if he did, he wouldnt need to start threads like this.</TD></TR></TABLE>
True. Hey, I did end up going OBD1 and everything went ok.
Thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">did you not read the post? he said EG.</TD></TR></TABLE>
And sry. I was in a hurry when I read this thread. I didn't even read anything else.
My bad.
Im out this thread.
Thanks for the help.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe »</TD></TR><TR><TD CLASS="quote">did you not read the post? he said EG.</TD></TR></TABLE>
My bad.
Im out this thread.
