HELP!!! installing Tein basic damper on 2000 GSR
ok so i got the stock shocks/springs out. and in the tein installation guide it says to remove the "brake hose clamp" to be reused on the Teins. but i can't figure out how to remove it. anyone know?
isnt there just a bolt that you unscrew to remove the brake hose clamps? each clamp should have a single nut (10mm) that you unscrew and re-screw on the teins
