F/S IBM P4 2.8Ghz HT 512MB CDROM
Old Apr 5, 2005 | 07:27 PM
I Want An Si's Avatar
Default F/S IBM P4 2.8Ghz HT 512MB CDROM
To Egay it goes....
http://cgi.ebay.com/ws/eBayISA...63788
Sold within hours... *****
Located in So Cal...pickup/delivery available
Shipping for this item will be $20(its HEAVY)
No tools needed to work on this computer just tabs and stuff... pretty neat when you need to get in and out quickly!
General Information - S50 Small Form Factor – (8184)
System board/
Form factor
Supports Intel 800MHz Front Side Bus (FSB), 512KB L2 cache, and built on a 0.13 micron core
Supports Intel Prescott Pentium 4 processors with 800MHz FSB, 1MB L2 cache, and built on a 0.13 micron core
478 pin mPGA socket
uATX
Processor
Intel Pentium 4 2.8GHz NORTHWOOD with HyperThreading installed(its like having 2 Processors!!!!)
Cache
512 KB cache
Chipsets
Intel 865G chipset graphics memory controller hub (MCH) integrated
ICH5 Input/Output Controller Hub integrated
AC '97 Digital Controller integrated
Memory
333MHz DDR (Double Data Rate) dual channel memory support
PC2700 (333MHz) memory support
Supports maximum memory up to 2.0GB
2 184 pin DIMM sockets
512 MB 333MHz DDR installed
Hard disk drive
Parallel ATA-100 7200RPM supported
Serial ATA-150 supported
40 GB 7200 RPM HDD installed
IDE controller
1 Ultra ATA-100 connector
2 drives supported
Serial ATA controller
2 serial ATA-150 connectors
2 drive support
Optical drives
CD-ROM Installed
Audio
Integrated ADI1981B
Modem
None provided
Power management
APM 1.2 and ACPI 1.0 compliant
Power-on suspend supported (soft on)
S3 supported, wake from USB & keyboard
Power supply
200 watt power supply
110 volt or 220 volt operation controlled by a switch on the back of the unit
Networking
Integrated Intel Pro/1000 Ethernet (gigabit) with Wake on LAN installed
Operating systems
Microsoft Windows XP Professional(LEGIT y0!)
Security
U-Bolt anchoring feature
Security slot for attachment of optional Kensington style cable lock
Power-on password
Configuration password (administrator password)
Boot sequence control
External ports
(8) USB (two in front, six in back) [Ver 2.0]
(1) ethernet RJ-45 network card integrated
(2) serial 9-pin ports 16550 compatible
One parallel port (LPT) IEEE 1284 compatible
PS/2 Keyboard, mouse, and 15-pin monitor ports
Microphone in, headphone out (front)
Audio line in, audio line out (rear)
Physical
85mm high x 309mm wide x 359mm deep (3.3" x 12.2" x 14.1")
Weight fully loaded - approximately 20lbs
Supports 100lb monitor
Horizontal or vertical orientation
Slots
Slot 1: full height, half length, 32-bit PCI 2.2 (5v)
Slot 2: full height, half length, 32-bit PCI 2.2 (5v)
Bays
Bay 1: 3.5 inch slim-line 1.2 inch, external access, floppy disk drive
Bay 2: 5.25 inch full-height, external access, CD-ROM
Bay 3: 3.5 inch slim-line, internal access, hard disk drive
SMALL COMPUTER and POWERFUL Package
Modified by I Want An Si at 12:51 PM 4/6/2005
Modified by I Want An Si at 6:22 PM 4/6/2005
Old Apr 5, 2005 | 07:55 PM
Default Re: F/S IBM P4 2.8Ghz HT 512MB CDROM (I Want An Si)
upppity
Old Apr 5, 2005 | 08:25 PM
fasdtg3w5hg
Old Apr 5, 2005 | 08:42 PM
Loaded Butane's Avatar
Bump for free stuff from work
.Joto
Old Apr 5, 2005 | 09:04 PM
Default Re: (Loaded Butane)
geoff es joto
Old Apr 5, 2005 | 09:49 PM
gfghe6udty
Old Apr 5, 2005 | 10:45 PM
sdfsdf45ys
Old Apr 5, 2005 | 11:27 PM
asdfasdgw35
Old Apr 6, 2005 | 12:53 AM
sdfgsdfgsd
Old Apr 6, 2005 | 01:21 AM
brad.'s Avatar
Bump for stuff Daniel steals from his work at OfficeMax,... yeah, that's right....OfficeMax
Old Apr 6, 2005 | 01:27 AM
Default Re: F/S IBM P4 2.8Ghz HT 512MB CDROM ([626]96-GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 &raquo;</TD></TR><TR><TD CLASS="quote">96-GSR]Bump for stuff Daniel steals from his work at OfficeMax,... yeah, that's right....OfficeMax</TD></TR></TABLE>
wtf? I dont even work at Officemax...!!lol
Old Apr 6, 2005 | 01:43 AM
brad.'s Avatar
LOL, ok fine.....Harbor Sound
BTW, my mama DOES like these deals
$14 Wireless mouse *shwing*
Old Apr 6, 2005 | 02:07 AM
buy this y0
Old Apr 6, 2005 | 06:25 AM
Good seller
Someone buy this so he can get his double cheeseburger off of layaway at McD's.
Old Apr 6, 2005 | 11:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane &raquo;</TD></TR><TR><TD CLASS="quote">Good seller
f u!
Old Apr 6, 2005 | 12:52 PM
Default Re: (I Want An Si)
asfdsaf3
Old Apr 6, 2005 | 01:38 PM
asdfasdf3wg
Old Apr 6, 2005 | 05:22 PM
Sold *****
E.Honda
May 4, 2007 08:31 PM
Sinner
Dec 19, 2006 09:05 AM
