spark racing pistons vs. topline
Old Apr 5, 2005 | 07:11 PM
teefunk01's Avatar
Default spark racing pistons vs. topline
Like the title says Spark Racing ITR spec pistons vs. Topline ITR spec pistons...
Id like to hear the good and the bad...experiences, reccomendations, etc..
Old Apr 6, 2005 | 11:58 AM
teefunk01's Avatar
Default Re: spark racing pistons vs. topline (tphan4)
no one?
Old Jun 9, 2005 | 09:04 AM
Hayaimoto's Avatar
well just to say that i used the topline pistons and they completly fucked my block up, the rings didnt hold in place, seemed like the rings where to small for the fitting. TOPLINE gets a from me, AND I did 2 identical blocks, standard size bored over to .20 (topline) and a .25 over bore on OEM itr pistons...did both at the same time, started booth motors in seperate cars at the same time, the topline motor smoked so i took it apart and check out the sleeves, completly scratched to hell, 3 of the rings on the topline pistons broke (oil control) but they did hold all the compression. thats my 2 cents
Old Jun 9, 2005 | 12:18 PM
revolt_allmotor's Avatar
Default Re: spark racing pistons vs. topline (JDMerzxCEO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMerzxCEO &raquo;</TD></TR><TR><TD CLASS="quote">well just to say that i used the topline pistons and they completly fucked my block up, the rings didnt hold in place, seemed like the rings where to small for the fitting. TOPLINE gets a from me, AND I did 2 identical blocks, standard size bored over to .20 (topline) and a .25 over bore on OEM itr pistons...did both at the same time, started booth motors in seperate cars at the same time, the topline motor smoked so i took it apart and check out the sleeves, completly scratched to hell, 3 of the rings on the topline pistons broke (oil control) but they did hold all the compression. thats my 2 cents</TD></TR></TABLE>
hmmm thats funny I am running toplines and my car smokes like a bitch. maybe something to check...
Old Jun 9, 2005 | 12:40 PM
Hayaimoto's Avatar
Default Re: spark racing pistons vs. topline (slowegxxrevolt)
if your going to use topline pistons....DO NOT USE THE TOPLINE RINGS....THEY SUCK ***!!!!!!!!!!!!!!!!
Old Jun 9, 2005 | 05:34 PM
vtecmissle's Avatar
thats funny running topline and having the same problems.
Old Jun 9, 2005 | 05:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMerzxCEO &raquo;</TD></TR><TR><TD CLASS="quote">if your going to use topline pistons....DO NOT USE THE TOPLINE RINGS....THEY SUCK ***!!!!!!!!!!!!!!!!</TD></TR></TABLE>
you know what though I think I used Honda rings but I can't remember... dammit to me
Old Jun 9, 2005 | 05:55 PM
sheepey's Avatar
Well. Spark Racing pistons are really Safety pistons, which are pretty good quality. Safety is good product. The rings in the topline sets are Hastings I believe, which are an ok ring.
Old Jun 9, 2005 | 07:25 PM
mtber's Avatar
Stop cutting corners & run oem pistons or go w/ a forged piston.
Old Jun 9, 2005 | 07:38 PM
Race Egr's Avatar
Default Re: spark racing pistons vs. topline (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Stop cutting corners & run oem pistons or go w/ a forged piston.</TD></TR></TABLE>
Oct 15, 2014 05:22 PM
Romo Pyro
Dec 2, 2009 04:11 PM
Mike K
31
Sep 2, 2005 08:34 AM
v4lu3s
Jul 19, 2004 12:45 PM
hooptie157
May 28, 2002 06:46 AM
