1990 accord won't start, searched but they didn't answer, please help
Old Apr 5, 2005 | 07:09 PM
TekSI's Avatar
Default 1990 accord won't start, searched but they didn't answer, please help
trying to start a 90 accord ex, auto, just a loud click and no crank. lights dim, so it's drawing plenty of current. the batter is perfect, 12.67V after sitting a few hours. short history: leaked oil, stopped, then started again, but i always added when it was below normal.
it does not crank at all...just the loud click of it connecting to the flywheel
Old Apr 5, 2005 | 11:34 PM
Intense3.2's Avatar
Default Re: 1990 accord won't start, searched but they didn't answer, please help (TekSI)
Make sure the starter is grounded correctly... sounds like a new starter is in need. you could try tapping the outside of it (the part that is furthest away from the tranny)... but be careful you dont touch anything with whatever you tap it with... or you will shock yourself.
Old Apr 6, 2005 | 02:24 AM
JonnySBeee...'s Avatar
had the same problem, sounds like a starter problem or maybe ignition...
Old Apr 6, 2005 | 05:03 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TekSI &raquo;</TD></TR><TR><TD CLASS="quote">... the batter is perfect, 12.67V after sitting a few hours...</TD></TR></TABLE>That doesn't really mean it's good. You need to test it with a load. Lots of bad batteries test OK for simple voltage with no load.
The load of the starter trying to crank probably draws the battery down a lot. Measure the battery voltage WHILE someone tries to start. If it drops down below say 8v or so, get a new battery.
Or measure battery voltage with all the headlights & blowers turned on. Or have it checked with a load at some carparts store.
If that checks out OK, then measure the voltage drop across each of the big battery cables while trying to start. If either or both are more than a fraction of a volt, clean up the corrosion, dirt, or tighten them or fix whatever you can find.
Old Apr 7, 2005 | 07:12 PM
joe's 93 accord's Avatar
motor is prob locked
Old Apr 7, 2005 | 07:20 PM
Intense3.2's Avatar
Default Re: 1990 accord won't start, searched but they didn't answer, please help (93 accord05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 accord05 &raquo;</TD></TR><TR><TD CLASS="quote">motor is prob locked </TD></TR></TABLE>
Wow what planet did you just come from? anyone else prob lock their motor due to an electrical problem?
poprocksncoke
Mar 22, 2014 05:55 PM
hondaon18's
Nov 12, 2012 06:13 PM
jwicecold
Jun 9, 2010 03:31 AM
ceyazzie
Jul 1, 2007 08:55 AM
