4th gen prelude wiring....HELP
Old Apr 5, 2005 | 04:48 PM
mxer518's Avatar
Default 4th gen prelude wiring....HELP
hey dose anybody have a service manual? i need to know about the 3 wire that goes into the connector for the coil on a h23 lude? the reason why i need to know what the three wires go to is because i baught a msd coil instead of a stock coil and i need to hard wire the wires to the msd coil..... here are the three wires:
black with yellow stripe
solid blue
soild yellow
Old Apr 5, 2005 | 05:14 PM
SiRLudeVtec's Avatar
Default Re: 4th gen prelude wiring....HELP (mxer518)
Hey - they have those Cd's off ebay for like $5 - the best damn manuals i've ever seen- they tell you EVERYTHING - from how to change your headlights to Understanding the way a vehicle Identification number is set up
Old Apr 5, 2005 | 05:43 PM
SKDRCR's Avatar
Default Re: 4th gen prelude wiring....HELP (SiRLudeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 &raquo;</TD></TR><TR><TD CLASS="quote">
solid blue
soild yellow</TD></TR></TABLE>
When I had a msd blaster coil, I used terminals to stick into the connectors
and ran extra wire to the coil and soldered the connection there.
This way you don't have to splice the connector.
The black with yellow stripe and solid yellow wires both go to the positive.
The blue wire goes to the negative on the coil.
Old Apr 5, 2005 | 07:41 PM
mxer518's Avatar
Default Re: 4th gen prelude wiring....HELP (SKDRCR)
i am taking th coil out of my h22 dizzy and hooking up the external coil so that i can get some spark. should i run the wires that are in the dizzy that origionally went to the internal coil to the external coil as if it were the same as the internal coil? or do i only need to run the negative wire back into the dizzy and hoook the positive of the coil right to the connector that the stock coil went to. this sounds kinda confusing... all i want to know is from the origional external coil connector where do i run the three wires to?
JSpekBB4
May 28, 2006 04:50 PM
connvict
Jul 29, 2004 08:54 PM
superturboprelude
Jul 8, 2004 05:10 AM
TheYellowDart
Apr 15, 2004 11:48 PM
darklude111
Mar 3, 2002 06:53 PM
