amp protect light-help
Old Apr 5, 2005 | 04:23 PM
BrownGSR's Avatar
Default amp protect light-help
just got a new car and it came with a stock si radio with a lighting amp hooked up to mb quart speakers (4) and a 10in jl sub. It worked fine for a couple of days and now, everything works, but no sound. The red protect light is on. Checked barrel type fuse right by the battery and the two fuses in the amp and they are fine. Took all the wires out except for the power, remote and gound and nothing still, just the damn red protect light. ANY HELP?????
Old Apr 5, 2005 | 04:43 PM
fcm's Avatar
fcm
Old Fart
Default Re: amp protect light-help (BrownGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrownGSR &raquo;</TD></TR><TR><TD CLASS="quote">just got a new car and it came with a stock si radio with a lighting amp hooked up to mb quart speakers (4) and a 10in jl sub. It worked fine for a couple of days and now, everything works, but no sound. The red protect light is on. Checked barrel type fuse right by the battery and the two fuses in the amp and they are fine. Took all the wires out except for the power, remote and gound and nothing still, just the damn red protect light. ANY HELP?????</TD></TR></TABLE> Check the speakers to make sure they are ok. you will need a multymeter, but you can just use a batt. 1.5 to 9 volt just to see if they pop then one by one, with one speaker, test all the outputs on the amp, turn amp off, hook up the speaker to one of the outputs and try it, if still no sound, amp is toast, replace it or have it repaired. 94
rufridn
Audio / Security / Video
Feb 16, 2009 12:58 PM
boostedeg302
Dec 29, 2007 10:01 PM
dr juice164
Jul 24, 2004 07:11 AM
D16Z6racing
Jan 21, 2003 12:13 AM
BoroDB8
Oct 15, 2001 01:09 AM
