Tuning Honda B-series with Innovate LM-1 Wideband and Hondata's ROM Editor
Old Apr 5, 2005 | 03:35 PM
7rrivera7's Avatar
Default Tuning Honda B-series with Innovate LM-1 Wideband and Hondata's ROM Editor
Is there anyone tuning Honda B-series engines with the Innovate LM-1 Wideband? If you have nailed the conversion tables for the LM-1 and Hondata's ROM Editor, please let me know the values you are using for the LM-1 output and the ROM Editor table because I'm close but still not consistant.
Thanks!
Old Apr 6, 2005 | 04:16 AM
7rrivera7's Avatar
Default Re: Tuning Honda B-series with Innovate LM-1 Wideband and Hondata's ROM Editor (7rrivera7)
Can anybody help me?
Old Apr 6, 2005 | 02:23 PM
7rrivera7's Avatar
ttt
Old Apr 8, 2005 | 09:14 AM
7rrivera7's Avatar
Old Nov 2, 2011 | 02:51 PM
lek9l's Avatar
you can setup the calibration of how many volts are going out on analog out on the LM-1 in LM Programmer if your trying to set the analog out and LogWorks if your using that software to datalog.
http://ht-archive.org/showthread.php?p=12601846
To make life easier, make sure you use resistor type spark plugs, my hondata would lock up because I was using non resistor spark plugs. Also, when you wire it up make sure you have good connection to the ecu.
LM-1 Wiring Install:
Red (Analog 1 Narrowband 0-1V) = Connect to D14
White (Analog 2 Wideband 0-5V) = Connect to B6, D10, D14 (Remove necessary capacitors if needed, I used B6 but you got to remove R2 and R3 capacitors)
Copper/Brown (Ground/Logical Ground) = Connect to A26
Now you program the LM-1 using LM Programmer which can be downloaded. It comes with Log Works so download that at:
http://www.innovatemotorsports.com/support.php
Use the serial cable connect it to the computer, if you don't got that then buy one, if you dont got serial port, you will have to buy a serial to usb converter for the lm1.
Once you have it connected, open lm programmer, and set the programmer to the following:
Narrowband Wideband
Analog 1 - Red Analog 2 - White
0V to 10.00 0V to 10.00
2V to 20.00 5V to 20.00
Now open hondata Smanager and set the following in the closed loop tab in the parameters window:
0V 5
5V 20
pbz Le
Northern California (Sales)
Dec 14, 2009 10:10 PM
SovXietday
Jun 20, 2007 08:50 AM
West Werks
12
Feb 4, 2005 08:06 AM
imlou
Nov 19, 2004 04:39 PM
importboi22
Aug 3, 2004 04:53 PM
