Crank Pulley wobble???
Old Apr 5, 2005 | 12:31 PM
spddmn124's Avatar
Default Crank Pulley wobble???
i have a 98 gsr, car runs great, no weird noises or anything. it has 59k miles, soon i have to get 60k tune up, today i was changde my oil. i turned the car on after oil change and was just inspecting the car... then i saw the crank pulley wobble, or should i say it looks like its unbalanced.. does it suppose to do that?? i thought that crank pulley are not suppose to wobble/move when engine is ideling?? i asked my friend to look a the crank pulley when i steped on the gas, he say it did not move/wobble when is reving...i dont know if you guys have any input in this please comment. thanks
Old Apr 5, 2005 | 01:33 PM
Racermech's Avatar
Default Re: Crank Pulley wobble??? (spddmn124)
is it stock? N1?aftermarket alloy thing?
Old Apr 5, 2005 | 01:50 PM
95lstegman's Avatar
Default Re: Crank Pulley wobble??? (Racermech)
just remember: the harmonic damper, or crank pulley, is there to dampen vibrations of the crankshaft, which are large and abundant. i've never watched mine while the engine is spinning since i keep the lower plastic on, but i wouldn't be surprised if it wobbled just a tiny bit. if it wobbles more than a hair, though, i'd take an impact wrench to it and make sure it's tight.
Old Apr 5, 2005 | 04:21 PM
Irish Integra's Avatar
Default Re: Crank Pulley wobble??? (95lstegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">i'd take an impact wrench to it and make sure it's tight.</TD></TR></TABLE>
doi it very soon before it causes any damage (if it is loose)
Old Apr 5, 2005 | 04:40 PM
spddmn124's Avatar
its stock pulley, it is very noticable, i dont know, i don tthink its loose, if it is loose it would have been off my car already (i drove like 70 miles today) can you guys look at your and tell me whats up???
Old Apr 6, 2005 | 08:50 AM
spddmn124's Avatar
anyone with this prob??
Old Apr 6, 2005 | 10:04 AM
Honda Hick's Avatar
Default Re: (spddmn124)
Your crank pulley should not be wobbling. Make sure the 19" bolt holding it on is real tight (I think it should be torqued to around 140 ft/lbs, something like that).
devilpuppy
Aug 30, 2024 09:15 AM
civikdude
Feb 13, 2009 02:17 PM
DARKTEG_
Aug 13, 2006 03:15 PM
asefi944
Apr 11, 2005 02:26 PM
