b16 arp rod bolt question
well,, ive built quite a few ls motors with arp rod bolts and they seemed to be fine... this is my first installation of arp rod bolts on a b16. of course they use the 9mm bolts.. but anyone who has every used these before did the cap have an extremely hard time coming off.. and if so what was your remedy...
thanks
thanks
Lightly tap on the cap sire to side w a hammer, should slide off without a problem, did you re size the rods on the other ls's that you built?
