problem with toda header
Old Apr 5, 2005 | 12:08 PM
bosco500's Avatar
Default problem with toda header
What is the deal with this header? I've searched around for an hour and cannot find the info I need.
I took this header to a local exaust shop to try and buy a flange for the exaust, and he did not have anything that would fit it. Does this thing require a 3" pipe? If not, will someone please explain to me how a 2 1/2" flange will fit this thing?
Old Apr 5, 2005 | 12:21 PM
UNKNOWN_MEMBER's Avatar
That's a 2.5inch collector. Find a 2.5inch flange.
Old Apr 5, 2005 | 12:25 PM
bosco500's Avatar
Well, thanks for the info. I guess the guy I took it to was a complete idiot, or he really didn't have the correct flanges. Do you have to have a flared flange, or does the actual exaust pipe have to be flared?
Old Apr 5, 2005 | 02:07 PM
PreStaged12s's Avatar
Default Re: (bosco500)
go to jhpusa.com and buy the OEM 2.5 donut for the JDM ITR header and while your there buy the Omni 2.5" test pipe, youll probably spend a little more than $100 cause I think the donut is like $25 and the test pipe is $80, it will be worth your time then to try to have a exhaust shop make you something.
Old Apr 5, 2005 | 05:49 PM
xtrafastcivic's Avatar
Default Re: (PreStaged12s)
there is a dohnut on there all ready... if you dont want to buy/use a testpipe.. you can buy something like this from http://inlinefour.com/25incolflan.html
Old Apr 26, 2005 | 11:23 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (XtraFastCRX)
JDM ITR cat bolts right up too
<---- Can verify, because it's on my car, unmodified.
Old Apr 27, 2005 | 05:06 AM
dwnthehatch's Avatar
I got my flange from kteller.com
Old Apr 27, 2005 | 05:37 AM
SMSP's Avatar
Default Re: problem with toda header (bosco500)
I flare the tubing to fit over the donut, like in my test pipes.
Then I use a floating flange, since not all headers position their collector flange the same way.
IM me if you have further questions.
Old Apr 27, 2005 | 05:44 AM
ar0nic's Avatar
Default Re: problem with toda header (SMSP)
check into the t1r cat killer. im very happy with it
Old Apr 27, 2005 | 06:48 AM
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
I used that as well for awhile, and Dave makes great stuff. Silly to say so for a test pipe, but that's the way it is
Old Apr 27, 2005 | 07:04 AM
fastlifemotorsports's Avatar
S2000 Donut Gasket should work fine.
Old Apr 27, 2005 | 08:13 AM
Suspetise...
Default Re: problem with toda header (fastlifemotorsports)
He's looking for a flange, not a gasket.
Old Apr 27, 2005 | 10:34 PM
zippyalex's Avatar
Default Re: (sscguy)
this guys isright. i have a toda on my DC2 catback as well. It is is on my civic m had some problem with the donut cos civic is way small, got am ITR's and all fit in snug.
Old Jun 4, 2005 | 08:26 AM
spoon23_JDizM AkA SpOoN20's Avatar
Default Re: (zippyalex)
just sell me your header and it will take away your headache...
DA9nEF9
Welding / Fabrication
Oct 1, 2014 07:03 PM
blackbettyek
Mar 29, 2010 07:18 PM
polishedturd
Jan 10, 2008 12:56 PM
jdm_ef9
18
Apr 4, 2005 03:54 PM
GSR_Hacker
Jun 27, 2003 11:34 PM
