Autozone Balljoints ok?
Old Apr 5, 2005 | 10:43 AM
Knightmare69's Avatar
Default Autozone Balljoints ok?
Just got off the phone with http://www.Hondaautomotiveparts.com and got quoted on balljoints for the prelude (4th Gen 4WS) fronts are like 200+ each side lower. Autozone has them for bout 65, Anyone running autozone balljoints? It's gonna cost like 1g to do all the balljoints on this car. *Sigh* TIA
Old Apr 5, 2005 | 11:29 AM
Jagan'92's Avatar
Default Re: Autozone Balljoints ok? (Knightmare69)
That honda price is probably for the entire knuckle assembly ? Just a hunch, but it's the same thing for the uppers - honda sells balljoints with the control arm.
Old Apr 5, 2005 | 11:54 AM
95PreludeSi's Avatar
Honda does not sell lower ball-joints for the prelude seperately. You have to buy the whole knuckle (I know as I just had one replaced).
200 is about right for the whole knuckle.
Now the question is.... Can they be pressed out? or do you have to replace the whole knuckle? I bet no, as honda lets you buy the bj for an integra, etc.... but not the prelude. I bet there is a reason.
fyi- remember, if your gonna replace the knuckle you should replace the wheel bearing too, as if you try to re-use the old one it will fall apart shortly.
Old Apr 5, 2005 | 12:56 PM
Great info ppl, thanks. I'm just confused cuz autozone has the lower balljoints listed seperatly.
http://autozone.com/servlet/Ui...dPage
It's just costing so much for this and the car is undrivable. Needs new balljoints, bushings and suspension.
Old Apr 5, 2005 | 03:44 PM
Jagan'92's Avatar
Default Re: (Knightmare69)
Looks like they can be pressed out - do a search in prelude archives for lower ball joint.
User petrv also mentioned some acura legend balljoints are interchangeable - you can buy them, yet still would need to press them out. Do the search, I saw some ghetto ways to get the joints out and in - and you could also take the balljoints to honda along with the knuckle and/or control arm and have them do the removal and install.
Old Apr 5, 2005 | 08:01 PM
jackstands's Avatar
Default Re: (Jagan'92)
Autozone loans out the press and all you need is a big socket to fit over the old balljoint and start hammering away. oh, take out the c-clip first.
brotherparker
Mar 5, 2009 05:13 PM
hondaracer142
May 7, 2007 06:19 PM
chihuahuamanx
Dec 7, 2004 12:29 PM
dustywebber
Feb 10, 2004 11:31 PM
