92-96 Prelude HELP!
if you are trying to run wires just follow the bundles that go through the firewall. i think it's near where the glove compartment is. i can go look outside at my brothers car if needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silly4lude »</TD></TR><TR><TD CLASS="quote">if you are trying to run wires just follow the bundles that go through the firewall. i think it's near where the glove compartment is. i can go look outside at my brothers car if needed. </TD></TR></TABLE>
Start from unbolting the fuse box in the engine bay. Look underneath it. Follow the wiring harness that goes into the firewall. Take a screwdriver, wrap the electrical wire around the tip of it and poke it through the grommet, but be careful not to cut any wires on the way in, and leave the screwdriver in there. Try to keep it as far away from the middle section as possible. It should enter the cabin right below the glove compartment, you'll have to peel back the carpet and insulation. Get under there, shine a flashlight and look for the screwdriver. Pull on the wire and there you are!
eluder33
Apr 8, 2005 08:31 AM
