JDM ITR Power Steering pumps
Originally posted in the ITR forum and received no replies. What was I thinking??
A question for the serious ITR guru's...
Recently, I had a 97' ITR motor dropped into my Civic (i know.. shoulda done it myself. 2 babies and a recent move made it tough). Since it's an autox project, I'm running PS, and I've got a GSR rack in the car right now.
Went to the junkyard where they have a wrecked ITR (may be a 99 i think) and bought all the PS hoses off it. When I got home, I discovered that the end of the PS hose that actually bolts to the compressor is a different size. The 2 bolts on either side of the opening line up, but the hose-end is too large to fit into the compressor.
So, here's my question. Did the ITR PS pumps change, or did the guy who did my swap not give me the pump that came with my motor? (possible, but not malicious) My plan is to go try and swap out PS pumps at the junkyard I bought the rest of the stuff from, but I'm curious to know the answer to this. Thanks!
This is what the flange looks like on my '95 GS-R PS pump. If the pump you're trying to use has a flange like this, then you need a '94-'97 Integra PS rack feed line.
I'm not sure if the '97 JDM ITR falls properly into these categories because when I created the picture, it only pertained to USDM Integra's.
Man, if I could buy you a beer...
That is exactly my delimma! Looks like you perfectly solved my mystery. My motor is a 97', but the pump hoses are from a 99'. Thus the larger fitting. Thanks so much for taking the time to post this!!!!
Stupid honda. Why'd they have to go and do a thing like that?!
Edit: Oops, forgot to ask... Does the 96-97' ITR hose end match the GSR pump flange? Thanks again!
EgSalad
18
Jun 11, 2009 11:38 AM
