adjustment of stock wastgate ... i searched....
Old Apr 5, 2005 | 09:46 AM
1990civicsiguye's Avatar
Default adjustment of stock wastgate ... i searched....
ok i read what was posted in one of the topics about adjusting the hook to raise or lower boost pressure. but is the hook the thing attached to the acuator or not .. i dont want to be turning on the wrong thing here. yea i know raising boost pressure is not recomended unless you have fuel and timing.... well im running 450's with turbo edit maps made for 10 lbs .. its a dohc zc just want to know how to raise it right ..ps im also intercooled. thanks in advance and i love the fact we worry about each others engines.
Old Apr 5, 2005 | 11:28 AM
ok so i figured out how to adjust it.. but now which way to go toward the wastgate it self or away from
Old Apr 5, 2005 | 12:07 PM
Evanmb44's Avatar
Default Re: (1990civicsiguye)
just pick up a cheap MBC and adjust boost that way. its much safer and you do not have to worry about ruining your actuator
Old Apr 5, 2005 | 05:27 PM
CWBETB's Avatar
There is just a nut you have to move on the wastegate to add more boost, check out http://thenew.gamesbbs.com/~dm...g.htm
Old Apr 5, 2005 | 07:44 PM
thanks guys after i posted this i kept looking and found just that article you are refering to cwbetb. thanks guys.
ls1goat
Dec 2, 2013 07:53 AM
GoHybrid
Mar 5, 2009 09:42 PM
nonvteclude
Jul 5, 2007 10:22 PM
grover
Sep 11, 2004 01:49 PM
