dc2's post your suspension mod list, ride height, and pics
post pics of your dc2's with a suspension mod list and how low it sits. this will help me and others from making any more topics like this, and will help me and others get ideas on our suspenion stuff as well.
TIA
Rob
TIA
Rob
koni yellows
ground controls
skunk2 camber kit
front and rear strut bars
not sure about the height, i just put it where i thought it looks good and rides good!
more pics in my cardomain, see sig.
ground controls
skunk2 camber kit
tokiko illumina 5 ways with ground control coil overs. also have stock gsr strut and a DC rear lower tie bar. i dont like my car slammed tho. i like going over speed bumps w/o ****** up my exhaust.
Omnipower Sports
also misc bars:
c pillar, front and rear strut, and ITR rear sway
this thread is kinda a repost, but eh..whatever
Tokico Illumina's, Ground Controls, neuspeed upper strut, neuspeed front and rear lower sway, z speed rear lower tie, no name rear upper strut, EM racing c pillar bar, and Energy susp. bushings.
i have no idea how far down the drop is....but all the pep boyz **** i have is
-buddy club full coil overs
-skunk2 front camber kit
-ingalls rear camber kit
-suspention tech rear sway and tie bar combo
-all 6 em racing bars
-sparco harness bar
-skunk2 front strut bar
maybe next go around ill put some money into suspension......
-sparco harness bar
Tein Flex w/ pillow mounts
Carbing 3 pt
ITR rear sway bar w/ BSQ kit.
ITR rear LCA's
Skunk2 Front Camber Kit
Ground Control Rear Camber Kit
Carbing 3 pt
ITR rear LCA's
^^ Those wheels look good on your car JPideda.
Clean
I got a simular setup with Ih8Ricerz:
GC coils/ Tokico Illuminas
Ingalls front & rear camber kit
ITR rear sway w/ BSQ kit
Don't really count the inches of drop... I just adjust to where it meets my driving standards.
CleanI got a simular setup with Ih8Ricerz:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yrethguad »</TD></TR><TR><TD CLASS="quote">What is the BSQ kit?</TD></TR></TABLE>
It's a subframe reinforment kit to help eliminate subframe tearout that is prone to occur when an ITR swaybar is mounted on a non-ITR Integra or other Honda.
It's one of three options I know to reinforce the subframe...
BSQ subframe reinforcement kit (http://www.geocities.com/bretq/mounting_kit.html)
BEAKS subframe reinforcement kit (http://www.beaksproducts.com)
COMPTECH tie-bar/subframe reinforcement (http://www.comptechusa.com)
BSQ - $20-25
BEAKS - $65
COMPTECH - $190 on eBay, seller aofeparts
Personally, I have the BEAKS kit, but I am considering changing to the COMPTECH piece. Since I have already installed the BEAKS kit (which means removing a tack welded nut) I will probably have to continue using the back half of the BEAKS kit.
JD
BSQ - $20-25
BEAKS - $65
JD
Koni Yellow Neuspeed SP3 Shocks
Eibach Sportline springs (1.7" claimed drop)
Ingalls Camber Kit F+R
Comptech 22mm Rear Swaybar
Brand-X both upper strut bars + both lower tie bars
I am riding on the "stock" perches on my konis, but in the front I have the ABS bracket removed, dropping the car another 0.5" or so. I would say theres about a 2.5" drop in the front, and a 2" drop in the back.... not too slammed w/ 17's.
