B20B Swap help
Old Apr 5, 2005 | 08:12 AM
1stcrxman's Avatar
Default B20B Swap help
I am doing a B20b Swap with a ITR head and was wondering two things. One, What head gasket should I use and two, can I use ITR connecting rods and crank in the B20B block? I would appercate any help on this.
Old Apr 5, 2005 | 08:22 AM
B SERIES US's Avatar
Default Re: B20B Swap help (1stcrxman)
why do u want to put itr crank in a b20 block?btw the headgasket u need will be a ls or b20 golden eagel makes a cr-vtec kit...make sure u have valve to piston clearance when u do that swap
Old Apr 5, 2005 | 08:41 AM
Mikey361's Avatar
Default Re: B20B Swap help (B SERIES US)
isnt a b18a/b basically a b20, same crank and basic block just a lil smaller bore. i could be wrong.
Old Apr 5, 2005 | 08:58 AM
Default Re: B20B Swap help (mle_92cx)
yeah but u said itr crank not b18a/b which is Ls that will shorten your stroke,keep the b20 crank less hassle.
1stcrxman's Avatar
I want a killer N/A Car and I heard that this combo will give it a 2.0 Displacement and I am going to run 11.1 to 1 comp. pistons, But if anyone has good ideas to build a nice engine, I would love to hear them. By the way, I own a 89 CRX Si.
Old Apr 5, 2005 | 09:08 AM
Mikey361's Avatar
build a lower comp. motor and boost it , then i can take my all motor car and whoop up on ya, hahaha, just search alot , find somthing that will find something to fit your goals and budget.
Old Apr 5, 2005 | 09:09 AM
if u run a stright b20 u have 2lit of displacement.as far as comp..it might be possible if u get the newer gen b20 98-up higher comp..with a itr head u should be close to or around 11.1 with out touching the motor or head
Old Apr 6, 2005 | 10:53 AM
1stcrxman's Avatar
Ok, so here's what my buddy's engine has, and he says he will sell it to me for $6500. B16a1 with cable tranny with crossed gears, CTR pistons, ITR Con rods, CTR Indurance Balanced crankshaft, ITR cam shafts, AEM cam gears, Spoon Balanced oil pump, Buddy club valves and valve springs, ITR Intake manifold and throttle body, CTR N1 Crank shaft, mugen valve cover, spoon kevlar spark plug cover, spoon header and Exedy clutch. Motor has 32000 miles on it and he got it new ( zero miles on engine ). I am seriously considering it, as he is not going to sell it if I don't want it. Anyone think it is a good idea??
yoRt
Dec 3, 2008 05:08 PM
frozenb
Oct 10, 2007 08:28 PM
iloveb16
Aug 6, 2007 10:05 AM
camlob
Apr 22, 2006 11:18 PM
