88 tranny spline count
Old Apr 5, 2005 | 06:55 AM
gutted-dx's Avatar
Default 88 tranny spline count
How many splines are there, i'm putting a DOHC ZC, with a 88 si tranny and need to know what flywheel.
Old Apr 5, 2005 | 07:48 AM
CRXVTEC69's Avatar
Default Re: 88 tranny spline count (gutted-dx)
21 splines
Old Apr 5, 2005 | 10:07 AM
gutted-dx's Avatar
Sio what flywheel should i use, an 88?
Old Apr 5, 2005 | 10:12 AM
Mach69's Avatar
Default Re: (gutted-dx)
If you use the '88 transmission, you must use an '88 clutch. You should use a '88 flywheel, I am 80% sure you can use an '89 flywheel as well, but definately not the '90-'91 flyhweels.
If you can, find a '90-'91 si transmission since the clutch disc is larger for more surface, thus more grip and less wear. You would use a '90-91 clutch and f/w combo for this.
Old Apr 5, 2005 | 02:39 PM
CRseXy's Avatar
Default Re: (Mach69)
I know for 100% you can use an 89 Flywheel. Cause I have an 88 Trans, 21(spline) with a 89 DX car.
Old Apr 5, 2005 | 08:29 PM
gutted-dx's Avatar
So i should use a 88 flywheel, Thanks for help
Old Apr 19, 2005 | 06:51 AM
gutted-dx's Avatar
On kingmotorsports it says to use a 90-91 flywheel with the 88 clutchs
Old Apr 19, 2005 | 06:58 AM
CRseXy's Avatar
no, wont work. 88 clutch and PP are small. the PP wont mount up to the Flywheel. the bolt holes are spread out to far for a 88 PP.
Old Apr 19, 2005 | 07:03 AM
dr_latino999's Avatar
Default Re: (pogiTSI)
88 - 21 Spline - 190mm Clutch/Pressure Plate/Flywheel
89 - 20 Spline - 200mm Clutch/Pressure Plate/Flywheel
90 - 20 Spline - 212mm Clutch/Pressure Plate/Flywheel
91 - 20 Spline - 212mm Clutch/Pressure Plate/Flywheel
If you would like to keep the 21 spline transmission, you can use a 84-87 Prelude 2.0L disk to achieve the 212mm clutch face and with this you can use the 90/91 Pressure Plate and Flywheel.
Modified by dr_latino999 at 11:08 PM 5/26/2007
Old Apr 19, 2005 | 07:34 AM
Servo's Avatar
Sorry to ***** up this thread, but I have an 89 tranny and motor from a CRX Si. Are the larger 90-91 fw/clutch/pp direct replacements? I need to buy all three, but I've been getting mixed info on what will fit.
Old Apr 19, 2005 | 04:15 PM
Default Re: (Servo)
Yes they'll work, hence forth why both years are 20 splines.
user 98292739
May 6, 2007 12:32 PM
vbspec
Jan 16, 2007 10:29 AM
pisetup
15
May 30, 2004 02:08 AM
nuc79
Feb 1, 2004 08:21 PM
CimorelliCRX
16
Dec 12, 2002 05:13 AM
