Door Lock Stuck
Old Apr 5, 2005 | 05:31 AM
FK00GSR's Avatar
Default Door Lock Stuck
My passenger side door lock is stuck in the locked position. I can manually move it into the unlock but when I try and used the power lock to unlock it just gets stuck. It makes a weird ticking noise like its stuck on something. However, if I manually unlock it and then hit the button to lock it works fine so I know its not the motor. Any ideas what to look for after I take the door panel off?
Old Apr 6, 2005 | 05:26 AM
FK00GSR's Avatar
Default Re: Door Lock Stuck (FK00GSR)
Anyone?
Old Apr 6, 2005 | 08:07 AM
AlxSiR7's Avatar
i just had the same problem but with my ds door and my keyless wouldn't unlock the doors. you dont need to take off the door panel.. just go to the lock itself (the part that clicks to the metal hook in the door jam) and push it in.. i think it's white. thats what worked for me anyway...
Old Apr 6, 2005 | 08:42 AM
FK00GSR's Avatar
Default Re: Door Lock Stuck (AlxSiR7)
Thanks dude, Ill try that once I get home this weekend.
Old Apr 6, 2005 | 11:19 AM
acuratuner00's Avatar
i had the same thing happen to me this past weekend...when i used the alarm to lock and unlock the door it still worked but the door lock didnt move, but for some reason after awhile it unjammed itself and it worked fine...
Old Apr 6, 2005 | 11:25 AM
FK00GSR's Avatar
Default Re: (acuratuner00)
Yeah, that's weird that it just fixed itself. I mean my car was sitting in my garage for about a month and when I went to take it out the door lock just got stuck. I'm hoping that since it broke itself it will fix itself. If not I hope the advice above works.
Old Apr 6, 2005 | 11:31 AM
simon98h22's Avatar
Default Re: (FK00GSR)
Taking the door panels off should identify a potential culprit pretty quick. It takes no time at all.
Old Apr 10, 2005 | 06:32 PM
FK00GSR's Avatar
Default Re: (simon98h22)
Ok, so i took the door panel off and sprayed some silicone on the locking mechanism inside the door. Works like a charm now. Thanks everyone for your suggestions.
LT Link
Nov 5, 2019 01:17 AM
JDMjukie
Mar 12, 2007 08:21 PM
rtcpenguin
Honda Civic (2001 - 2005)
10
Aug 3, 2006 07:39 PM
bboylito
Dec 9, 2004 04:52 PM
es four
May 20, 2002 11:44 AM
