Diagnostics???????????????? 89 crx base model.... wont start... need to code my ecu...
I have an 89 crx that wont fire... it cranks over but just wont fire and everytime I turn my key on my check engine light goes off after a sec but then when I start to turn it over the check engine light comes on and it doesn't start! so confused plz hlp.
well, when I turn my key to acc. I can hear my fuel pump kick on I left my keys at a friends so I can't check my spark plugs but I was thinking that it might be my main relay but I am not sure about that either. I just don't wanna buy a bunch of parts that I don't need but who knows. I did replace my ecu, distributor and cap, rotor, spark plugs and wires about 6 months ago but I have put about 6000 miles on tham so.... maybe I will just try a tune-up and see what happens.
turn your keys to the "on" position, pull back the carpet on the passenger side floor. you should see a bracket holding down your ECU. you should also see a blinking LED light on the ECU. count the long flashes and short flashes. long=10 and short=1. search for a list of codes for your engine then diagnose the problem.
PS: search is in the upper righthand corner
or you can look at the thread entitled "FAQ" stickied at the top of the forum and look for something called ECU code listing. goodluck
ok here's the deal I am pulling a code 16 which is an injector problem... now I am kinda new to all that. do you know of a site where I can get info about my injector system???
toytroy
Sep 27, 2012 10:06 AM
Lucky-13
Mar 23, 2007 09:33 PM
sickerhatch
Sep 10, 2005 06:14 PM
blakryder1
Sep 11, 2004 10:04 AM
