9000RPM DESTRUCTION!!!
Old Apr 5, 2005 | 02:19 AM
EG6R's Avatar
Default 9000RPM DESTRUCTION!!!
So i wanted to test my newly built B16 on the track. Here is the link: https://honda-tech.com/zerothread?id=1192506
I was nearing the finish line in fourth gear when suddenly the engine siezed and died. Took it apart and this is what i found.
A valve dropped.
Both head and block suffered permanent damage and can no longer be used.
Modified by EG6R at 3:34 AM 4/5/2005
Modified by EG6R at 3:36 AM 4/5/2005
Old Apr 5, 2005 | 02:21 AM
UNKNOWN_MEMBER's Avatar
**** that sucks man. So the omnipower valvetrain failed? I thought they were meant to be took past 9k? Look at the bright side, bigger motor
Old Apr 5, 2005 | 02:40 AM
EG6R's Avatar
Default Re: (UNKNOWN_MEMBER)
The retainers and springs are all still in good condition. The valve broke in half and dropped. I am charging it to wear and tear.
Old Apr 5, 2005 | 03:07 AM
Stock valves?
Old Apr 5, 2005 | 03:16 AM
EG6R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">Stock valves?</TD></TR></TABLE>
yes
Old Apr 5, 2005 | 04:17 AM
Chillinit's Avatar
Default Re: (EG6R)
that sucks dude..I think that motor was on its way out regardless....considering the power you put down.
DefiantGSR
Aug 1, 2009 11:08 AM
whiteguyndahood
Dec 25, 2007 12:20 PM
boosted_TSi
Oct 18, 2006 05:18 PM
Andre
Sep 18, 2003 07:57 AM
