Free Head Light Buzzer
Old Jan 28, 2002 | 02:28 AM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Free Head Light Buzzer
Im such a cheap-o.... What cha do is. 1. Take the little circuit board out of your seatbelt junk on the rearveiw mirror, Just unplug it... 2. Get some wire (some cheap speaker wire will do the trick) And only strip one end about 1/2 an inch... 3. Take the unstriped end of the copper wire and push it down onto the 2nd post from the outside of the board (If you have already taken out the circuit board youll see what Im talking about) And do the same with the silver wire on the last post (furthest away from the outter edge of the board).... 4. Now open up your fuse box under the dash, Take the #8 fuse out and plug the copper wire in with the fuse, The silver one is the same only with fuse #1.... Your done, Go ahead man test that sucker out... Turn your car on and the lights too, Leave your lights on and turn the car off, If you miss that... You can't hear. Do this at your own risk, If you need help post mang
Modified by h8tred at 4:39 AM 11/22/2003
eric416
Jun 28, 2006 04:14 PM
pompous
Dec 23, 2004 08:57 AM
S13 slide
Jan 20, 2002 10:35 PM
95gsr
Sep 18, 2001 09:25 AM
