koni perches...only for stock springs?
are the koni perches used for only stock springs? anyone using the lowest perche on lowering springs like H&Rs?
i did a search and someone said "lowering a car with both lowering perches and lowering springs is going to have a cumulative lowering effect and it is quite easy to over lower your car this way with what will likely be too soft a spring rate for that height then."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted ek »</TD></TR><TR><TD CLASS="quote">are the koni perches used for only stock springs? anyone using the lowest perche on lowering springs like H&Rs?
i did a search and someone said "lowering a car with both lowering perches and lowering springs is going to have a cumulative lowering effect and it is quite easy to over lower your car this way with what will likely be too soft a spring rate for that height then."</TD></TR></TABLE>
I think that someone was CRX Lee ..... he runs Koni North America, so he probably knows best. That being said, I've driven with my Pro-kits set to the lowest perch for a while now. Nothing bad has happened, but I'm playing with fire. As soon as I get ready for an alignment I'm going to put it back to the middle perch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense »</TD></TR><TR><TD CLASS="quote">I think that someone was CRX Lee ..... he runs Koni North America, so he probably knows best. That being said, I've driven with my Pro-kits set to the lowest perch for a while now. Nothing bad has happened, but I'm playing with fire. As soon as I get ready for an alignment I'm going to put it back to the middle perch. </TD></TR></TABLE>
how long have you been riding on the lowest perch? i really wanted shocks that can lower my car a little bit more. but if the perches are only for stock springs, then there's no point in buying the konis. i guess i'll save my money and get the kyb agx. i'm not a hardcore autox'er.
only a couple thousand miles, but I'm very carefull about hitting potholes and stuff.
If you're not looking for top performance, then just go with KYBs.
</TD></TR></TABLE>only a couple thousand miles, but I'm very carefull about hitting potholes and stuff.
