need help ASAPPPP plz
Old Apr 4, 2005 | 10:43 PM
sanitarium's Avatar
Default need help ASAPPPP plz
my friend has a 91 teg....he put a gsr in it....with a b16 tranny and a b16 ecu....its obd 0 hes having problems when he starts it up....it boggs out like its ready to stall.....wen he gives it gas same thing it runs fine for about 10 seconds then it starts boggin out.......the ecu gave him a code for the injectors.....so we think hes not getting enough fuel....if ne one has ne info about this...or what the problem can be let me kno asap thanx....
Old Apr 4, 2005 | 10:59 PM
vtec_joe's Avatar
Default Re: need help ASAPPPP plz (sanitarium)
check the distributor and the wiring on that, im guessing it could be from that
Old Apr 4, 2005 | 11:22 PM
G2integra217's Avatar
Default Re: need help ASAPPPP plz (vtec_joe)
What is there to check on the wiring on the distributor?The order of plugs is correct and it had spark.
Old Apr 5, 2005 | 12:10 AM
Old_Honda's Avatar
Default Re: need help ASAPPPP plz (g2integra217)
Well since its throwing a code for injectors i would check them out first, maybe they're dirty/clogged?
Old Apr 5, 2005 | 06:07 AM
Backk InTheDA's Avatar
I hate everything
Default Re: need help ASAPPPP plz (OldGSR)
A good way to test your injectors, is, well, in your case, since the engine wont stay on for to long, you'll just have to hurry. Take a long screwdriver, and touch the metal part to the injector, and then put your ear directly on the screwdriver, if you hear clicking, your injector is fine, if you don't, there's your problem.
Good Luck
iTR
Hammtheman
15
Oct 15, 2009 12:44 PM
mother ef-er
22
Oct 5, 2009 07:20 AM
H22Ej1
11
Jul 26, 2009 10:16 PM
apekd
Jan 15, 2009 04:57 PM
pinoyboy204
Oct 9, 2003 04:57 PM
