cv joints/ axles something wrong
Old Apr 4, 2005 | 10:37 PM
lilman4o8's Avatar
Default cv joints/ axles something wrong
my cousin has a 92 accord, when he turns it makes a clicking noise, i'm sure it has somthing to do with his axles. i'm not really good at cars but i read another post and some guy had the same problem as my cousin, they said somthin'g about a cv joint and stufff, what is a cv joint and is there a way i can buy a manuel n do this at home, sorry for the many duplicates of these type of problems.
Old Apr 4, 2005 | 11:56 PM
SpeedFreak77's Avatar
Default Re: cv joints/ axles something wrong (lilman4o8)
Yeah you can do it pretty easy at home.
Old Apr 5, 2005 | 04:44 AM
Monkey Fing a Coconut's Avatar
Default Re: cv joints/ axles something wrong (SpeedFreak77)
yeah it is definately the cv joint, if not the entire axel, a haynes from autozone for like $12 will walk u through it, or u can get a helms (www.helmsinc.com i think) will go into more detail, plus tells u how to do everything else with the car, its a factory repair manual, but the clicking is definately the cv
Old Apr 5, 2005 | 03:11 PM
YeuEmMaiMai's Avatar
in a nutshell you can do this
remove tie rod and big-**** nut on wheel
rotate wheel out
remove driveshaft
reverse to install.
I am pretty sure you will not have to take the ball joint off buy you might.
with an impact wrench it should take about 15 mins a side.
Old Apr 5, 2005 | 04:05 PM
raceACCORDingly's Avatar
much easier with the lower ball joint disassembled.
Old Apr 5, 2005 | 04:08 PM
Schmitey's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">with an impact wrench it should take about 15 mins a side.</TD></TR></TABLE>
I doubt that one mechanic at a dealership could do it that fast, and certainly not anyone who's never done it before!
Old Apr 5, 2005 | 04:13 PM
Default Re: (Schmitey)
I watched a mechanic at my friends goodyear shop do my axle in about 15 mins all by himself. It isn't that hard if you have the proper tools. ( i don't)
When the honda dealer changed my timing belt, it took 1 guy 90 minutes from start to finish.
Old Apr 5, 2005 | 09:00 PM
i can do an axle about 30 mins a side taking my time. including getting the axle nut and lower ball joint off and using all hand tools.
Old Apr 6, 2005 | 10:07 AM
Schmitey's Avatar
Default Re: (raceACCORDingly)
yeah, i guess the ball joint is the biggest thing
even with the pry tool it was a bitch! My dad and i went so far as to wrap a chain around it and use a two ton bottle jack to push it out with no effect!!! What finally did it was out of desperation we got out the air chisel and hammered on it. Sprayed it with WD40, went in for dinner, and it popped right out. I also couldn't get the tension bar or whatever the hell its called back in place, the bar with the huge rubber mounts near the bumper.
Old Apr 6, 2005 | 07:06 PM
lilman4o8's Avatar
aite thanks guys, appreciate the info.
thirdgear
Oct 16, 2010 05:21 PM
Shorty C
May 15, 2004 06:10 AM
hankd
Oct 26, 2002 05:04 PM
projecthybrid04
Sep 26, 2002 06:38 AM
95gsr
Jun 1, 2002 12:32 PM
