Is it smart to tune a 2000 gsr with just a vafc?
Old Apr 4, 2005 | 07:29 PM
Integgin's Avatar
Default Is it smart to tune a 2000 gsr with just a vafc?
2000 gsr...basic bolt-ons...maybe a skunk2 intake manifold in the future....would it be smart to have the car tuned on the dyno with a wideband o2 sensor and just a vafc-II??? cuz with the vafc i dont have to convert my ecu..it works with the 00-01 gsr's....but if it is tuned right...will i be able to get some power outta it? Thanks!
Old Apr 4, 2005 | 09:12 PM
Kendall's Avatar
You'll be able to get a couple horses out of it, but for less money you can get a socketed P28 and a conversion harness. Then take it to a dyno where someone can put together a map for your car. I'm guessing you'll have no more than $350 in it if you do it this way.
Old Apr 4, 2005 | 09:18 PM
jin_gsr's Avatar
Default Re: Is it smart to tune a 2000 gsr with just a vafc? (Integgin)
virgin p28, conversion harness to obd1, UBERDATA ALL THE WAY >
Old Apr 5, 2005 | 02:07 AM
greasemonkee's Avatar
A dyno is out of the question for me so VAFC is the way I went. With my wideband I can set it right where I want. The down side is that you can't change the timing, but unless you're making considerable numbers over stock, it may not be necessary.
Old Apr 5, 2005 | 05:47 AM
JamaicanDM's Avatar
Default Re: Is it smart to tune a 2000 gsr with just a vafc? (jin_gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin_gsr &raquo;</TD></TR><TR><TD CLASS="quote">virgin p28, conversion harness to obd1, UBERDATA ALL THE WAY &gt;</TD></TR></TABLE>
u cant use the p28 without the skunk2 manifold because it wont open the butterflies, but for now a vafc would work now
H22Honda98
Aug 4, 2007 10:39 PM
OneFastGsr
Oct 6, 2003 07:57 AM
ludefreek
Nov 7, 2002 09:19 PM
IgniteTeg
Sep 18, 2002 11:19 PM
IgniteTeg
Sep 16, 2002 07:09 PM
