Just Pass Smog!!!
GREAT news!! I just pass my emission test today at the referee
. The thing that sucks was that it overheated the first time because the fan wasn’t on. The result was the
15 mph HC: MAX 147 MEAS 19 CO: MAX .88 MEAS 0.00 PASS
25 mph HC: MAX 122 MEAS 20 CO: MAX .78 MEAS 0.01 PASS
BEFORE
15mph HC: MAX 147 MEAS 216 CO: MAX .88 MEAS 6.28 GROSS POLLUTER
25mph HC: MAX 122 MEAS 216 CO: MAX .78 MEAS 6.30 GROSS POLLUTER
THANKS FOR ALL THE ADVISE CRX/EF Civic Driver!!!!!!
. The thing that sucks was that it overheated the first time because the fan wasn’t on. The result was the 15 mph HC: MAX 147 MEAS 19 CO: MAX .88 MEAS 0.00 PASS
BEFORE
Changed the catalytic converter with the exhaust, oil, spark plug, O2 sensor, Guarantee to Pass Emission Test from Pep Boy’s, and used the V POWER from Shell to clean my vacuum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="blue">Changed the catalytic converter with the exhaust, oil, spark plug, O2 sensor, Guarantee to Pass Emission Test from Pep Boy’s, and used the V POWER from Shell to clean my vacuum. </FONT> </TD></TR></TABLE>
<FONT COLOR="red">Hey FOMULA91,
What octane did you use when you filled up? also can you post the rest of the numbers you got on your sheet? I have also done those same things last year....and just barely passed...I have since, though, replaced my wires and plugs and I believe that I would pass with a much better score....great job and thanks for the heads up. I will need to do the same for mine.</FONT>
First, I used V Power (91 from Shell Gas Station) to mix with guarantee to pass emission (product to help pass the smog test) from Pep Boy’s. After driving like 350 miles, I filled up with 89 premium to take the test at the referee. Before taking the test, I drove like 15 to 20 minuets to warm up my cat. Then my CRX pass with no problem.
