starting my lsvtec build (what do you think?)
Old Apr 4, 2005 | 07:03 PM
U N S E E N.'s Avatar
Default starting my lsvtec build (what do you think?)
im using a b18b block
shot peened rods
ctr pistons
polished and balanced crank
gsr water pump
2000 si b16 head
jerry built street strip port and polish
sk2 stg3 cams
sk2 cam gears
sk2 valves, valves springs, retainers
tmw itbs 48 mm
and for a header i would like a dtr but i dont know if i will have any money left over
im selling my EG to do this so tell me what you think
Old Apr 4, 2005 | 07:08 PM
Combustion Contraption's Avatar
Ditch the stage 3's.
Pop in some buddy club 4's, have alazniz do your headwork. ITB's are awesome, but a bitch to tune. This sounds like you want it to be a race engine. If so, get some decent forged internals, then you can go w/ the stage 3's and jerry built headwork w/ itb's...
Old Apr 4, 2005 | 07:11 PM
Default Re: (LsVtec92Hatch)
i want a streetable motor that will hit around 200 hp. this is my daily driver, oh yeah i was planing on tuning with a s200
Old Apr 4, 2005 | 07:23 PM
Ekay Jay's Avatar
Default Re: (TODA2nr)
I wouldnt get the skunk2 valvtrain, iv heard way too many stories of valve sprigs breaking. Might want ta look into getting some others.
Old Apr 4, 2005 | 08:49 PM
A streetable motor that will hit 200?
No port/polish, no crazy cams, stock 81mm bore, stock 89mm stroke, shitty dc 4-1 header, shitty crush bent exhaust to a no name muffler.
Hondata of course. You dont need all that stuff to hit 200whp, especially itb's. Put your money in the right places and youll walk away veeeery happy.
Old Apr 4, 2005 | 08:52 PM
WTF?! thats crazy what setup is that guy running?
Old Apr 4, 2005 | 08:55 PM
That guy? Thats me...
Its real basic. pr4 rods, p72 pistons, gsr head, omnipower valve train, flat faced valves, buddy club spec 3's.
Old Apr 4, 2005 | 09:00 PM
k2490si's Avatar
Default Re: starting my lsvtec build (TODA2nr)
you should be able to get 200whp without crazy cams and port job. Like the other guy said.
But I would probably stay away from the skunk valve train. I have seen 2 failures here in the last 6 months= lots of damage. 1 valve broke, and the other was spring breaking. Oh yea they do not warranty those parts.
Old Apr 4, 2005 | 10:23 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODA2nr &raquo;</TD></TR><TR><TD CLASS="quote">im using a b18b block
shot peened rods
ctr pistons
gsr water pump
2000 si b16 head
sk2 stg3 cams
sk2 cam gears
tmw itbs 48 mm
im selling my EG to do this so tell me what you think </TD></TR></TABLE>
You're missing a few things.
ARP Rod bolts
ARP head studs
GSR/ITR Oil pump
Ditch the S2 valvetrain with something like Crower or Ferrea
What pistons are you going to be running with this setup? Hopefully some CTRs
If you plan on revving past 8k-85 (you most likely are...), it would be wise to use a Main girdle, and forged rods... Balance your rotating assembly while you're at it.
Old Apr 4, 2005 | 10:26 PM
It says he will be running CTR pistons. I dont think he needs them. I personally believe he'd be better off with a set of p30's or pr3's. You can make up the loss in compression with timing/fuel/overall tuning.
Old Apr 4, 2005 | 10:37 PM
UNKNOWN_MEMBER's Avatar
Don't forget to subtract 5-10hp from that graph if you're going to dyno it on a dyno jet.
Old Apr 4, 2005 | 10:52 PM
Default Re: (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to subtract 5-10hp from that graph if you're going to dyno it on a dyno jet.</TD></TR></TABLE>
either way, very close to 200whp. Easily attainable with a better header.
Old Apr 4, 2005 | 11:02 PM
thevanitygroup's Avatar
I agree, 200whp on the 89 crank should not be hard. Want a cheap and reliable combo?
B18 BLOCK
-P30 pistons
-NPR rings
-ACL bearings
-ARP rod bolts
B16 HEAD
-Type R outer valve springs
-Portflow inner valve springs
-Portflow retainers
-Buddy Club Spec 3+ cams
-ARP head studs
-B16 throttle body
-AEBS intake manifold
-ITR header
&gt;Adjustable cam gears
&gt;Adjustable fuel pressure reguator
P28 ECU chipped
-Apex VAFC I
SPEND THE REST ON TUNING...
Old Apr 4, 2005 | 11:08 PM
Default Re: (thevanitygroup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevanitygroup &raquo;</TD></TR><TR><TD CLASS="quote">I agree, 200whp on the 89 crank should not be hard. Want a cheap and reliable combo?
B18 BLOCK
-P30 pistons
-NPR rings
-ACL bearings
-ARP rod bolts
B16 HEAD
-Portflow retainers
-ARP head studs
-B16 throttle body
-ITR header
P28 ECU chipped
-Apex VAFC I
SPEND THE REST ON TUNING...</TD></TR></TABLE>
Everything looks good but with the price of hondata getting lower and lower and the amount of people using it to tune going up and up and i would STILL spend the money and get something that can do igntion.
Old Apr 4, 2005 | 11:09 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">It says he will be running CTR pistons. I dont think he needs them. I personally believe he'd be better off with a set of p30's or pr3's. You can make up the loss in compression with timing/fuel/overall tuning. </TD></TR></TABLE>
ctr piston compression with 89MM crank is way high.to each their own though..lets see some graphs when its done
Old Apr 4, 2005 | 11:13 PM
Default Re: (1.6i)
^ An LS with CTR's is too high compression wise, plus the CTR's are a heavier piston and have a high dome which dosent help with equal chamber combustion and flow. The compression with the P30's is in the mid to high 11's and that perfect pump gas area. Hookups and R&D made 250+HP in the Allmotor shoot out with 11.5.1 compression ...
Old Apr 4, 2005 | 11:29 PM
Plus this guy right here has some for sale for $179!
Old Apr 5, 2005 | 12:14 AM
Actually no I dont... hahah ... Ran out.. I need to delete that..
Old Apr 5, 2005 | 01:24 AM
You can always go for some jdm itr pistons. Spark Racing has a deal on them. They arent OEM though. What octane are you going to be using? I'd also ditch the s2 valvetrain and cams as well. Maybe go omnipower or RM for valvetrain. And some m22s.
Old Apr 5, 2005 | 01:29 AM
i was originaly gonna go with jdm itr pistons, but the i heard ctrs are better. i would be running 91 octane, just regular pump gas.
Old Apr 5, 2005 | 01:33 AM
I'd go with the jdm itrs when running 91 octane. It aint good to have high compression and can't back it up with good gas, atleast 93octane or something. But yea, go with the jdm itrs. I'd rather have the ability to advance timing rather then have it retarded.
Old Apr 5, 2005 | 01:51 AM
The Honda OEM P30 piston are the best factory cast B-SERIES all motor piston available. In applications where it dosent boost compression, milling the head is the course of action that should be taken.
CTR's in a LS/V is too much compression! In california, while using pump gas, one should NEVER exceed 11.5.1 compression ratio!!
Old Apr 5, 2005 | 02:08 AM
werd and as for valve train i dont really know what to go with now, or what cams.
Old Apr 7, 2005 | 10:29 PM
AnDru's Avatar
lol... this oughta be good tony
Old Apr 8, 2005 | 12:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODA2nr &raquo;</TD></TR><TR><TD CLASS="quote">werd and as for valve train i dont really know what to go with now, or what cams.</TD></TR></TABLE>
Omnipower, or rocket valvetrain is good.
With cams, just make sure you dont go to big, and kill your mid range.
