Suspension & Brakes Theory, alignment, spring rates....
Am I correct with this...
Old Apr 4, 2005 | 05:52 PM
ProjectLSVTEG's Avatar
Default Am I correct with this...
I am purchasing a full set of Tokico Blue struts on Friday for my car.
My question is this. The struts as of right now are on a ek hatch, and I plan on using them on my DA integra. It is my understanding that the rears will fit fine, but in order to make the front struts fit my DA, I will need to use the front forks from either a DC/EG/or EK. I called up a friend who has a spare set of forks, and is giving them to me, I just wanted to make sure it will work, before I go through all the trouble of ripping my suspension apart.
Any info is appreciated, thank you.
Old Apr 5, 2005 | 08:51 AM
Default Re: Am I correct with this... (ProjectLSVTEG)
nobody knows?!
Old Apr 5, 2005 | 08:54 AM
Smashback's Avatar
Never heard of that one before. Not sure. I do have a set of tokico blues from my ek in perfect shape, low low miles if you need more though
Old Apr 5, 2005 | 09:55 AM
turbohappy's Avatar
That is certainly true for an EF or a 2g CRX, that's the setup I have. Can't be 100% on the DA, haven't really done anything with one personally.
Old Apr 5, 2005 | 11:01 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Am I correct with this... (turbohappy)
The EK rear LCAs are skinnier than the EF/EG/DA/DC rear LCAs. This means that the lower mount of the EK's rear shocks won't fit over the DA's bushings. I know that you can grind the ends of your bushings down so the shock will fit over them, but that is a little ghetto in my opinion. I have also heard that you can have EK bushings pressed into the DA LCAs, but I've never seen it done so I don't know if they really do fit or not...
Good luck.
PS: Your front end may ride higher with the EG/DC/EK front shock forks...
Old Apr 5, 2005 | 12:01 PM
Default Re: Am I correct with this... (94eg!)
alright, thanks for the info, more would be appreciated, I'll keep searching around too, and I really only need one set of struts, thanks though
goldgreen90ef
Oct 29, 2009 07:20 PM
hueyduey
Suspension & Brakes
Sep 4, 2006 11:22 PM
90efcivic
Feb 9, 2006 11:42 AM
hellogoodbye
Jan 17, 2006 03:06 PM
spock_rocker
11
Aug 13, 2003 05:23 PM
