skunk 2 stage 3 cams with usdm p30 pistons
Old Apr 4, 2005 | 05:52 PM
redlseg's Avatar
Default skunk 2 stage 3 cams with usdm p30 pistons
will i have enough valve clearence? i have a b16 head and a b18c1 bottom end
Old Apr 4, 2005 | 07:00 PM
redlseg's Avatar
Default Re: skunk 2 stage 3 cams with usdm p30 pistons (95eg6allmotor)
up
Old Apr 4, 2005 | 07:05 PM
Combustion Contraption's Avatar
Your valve clearance will be fine.
Your powerband will be horrible.
Your idle will be horrible.
Your cam selection IS horrible.
Old Apr 4, 2005 | 07:30 PM
redlseg's Avatar
Default Re: (LsVtec92Hatch)
LsVtec92Hatch
Online
2503 posts [99%]
99 percent for 6 months now and no explanation.
1-31-2003
« « » 8:05 PM 4/4/2005 Reply Edit
why would my powerband be horrible? and my idle?
redlseg's Avatar
LsVtec92Hatch
Old Apr 4, 2005 | 07:31 PM
redlseg's Avatar
Old Apr 4, 2005 | 08:36 PM
Easy there, turbo.
Your idle will be **** because your using a race cam. Thats normal. Theres so much overlap that your pumping exhaust charge back into the intake as well, thats another reason for the poor idle.
You wouldnt be able to keep your bottom end together long enough to make power with those cams. You'll be bleeding off so much compression down low you wont make power til 7-8k is my guess....
Old Apr 5, 2005 | 09:20 AM
Jasper_db1's Avatar
What USDM P30 piston!?
Old Apr 5, 2005 | 09:30 AM
PreStaged12s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Easy there, turbo.
Your idle will be **** because your using a race cam. Thats normal. Theres so much overlap that your pumping exhaust charge back into the intake as well, thats another reason for the poor idle.</TD></TR></TABLE>
Thats not a true statement, I have Skunk stage3s in my street car and it idles fine, better than my friends car with Toda C's, the primary and secondary lobes on that cam arent that crazy, its the VTEC lobe that is crazy, it will idle fine, sometimes its a bitch to start it up in HOT weather, other than that its fine.
Also 95eg, you need lots of compression to run that cam, there are several posts on HT about that particular cam, everybody says the same thing, you need lots of compression and good head flow to make those cams useable.
Modified by PreStaged12s at 11:36 AM 4/5/2005
Old Apr 5, 2005 | 10:05 AM
GUILOTINE's Avatar
Kill Gil
Default Re: skunk 2 stage 3 cams with usdm p30 pistons (Jasper_db1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">What USDM P30 piston!?</TD></TR></TABLE>
I think the newbie is refering to a USDM PR3 piston and the answer is <FONT SIZE="6">NO!</FONT>
Old Apr 5, 2005 | 10:52 AM
Default Re: (PreStaged12s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreStaged12s &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by PreStaged12s at 11:36 AM 4/5/2005</TD></TR></TABLE>
Just curious, but what octane are you running?
Old Apr 5, 2005 | 12:34 PM
chameleon's Avatar
ok lets set things straight here before the people who really know what they are talking about finally step in.
1 - skunk2 st3s will idle fine, they have a large vtec lobe but their idle is almost like stock, why because a friend of mines runs them with a chipped computer and the car behaves like stock.
2- with jdm p30 pistons his compression would be in the 11.8's which should be fair for a large cam, would be better if he was a 2ltr
3- octane of gasoline pertains to compression not idle
Old Apr 5, 2005 | 12:52 PM
Default Re: (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">
3- octane of gasoline pertains to compression not idle</TD></TR></TABLE>
Octane pertains to detonation resistance pertains to igniotn advance/retard pertains to nice smooth idle.
Old Apr 5, 2005 | 01:57 PM
AllMotr's Avatar
I run s2s3 cams with p30s in my lsvtec untuned on 94 octane and it idles really good(850rpms) for not even tuned, i will be going for tunning soon and post my results, all i hear is that skunk2s3 cams are horrible for street and don't idle worth ****, but in my lsvtec i love them and will love them more when they get tuned for my engine. i also rev my lsvtec to 9200 with gsr girdle and acl bearings no problem.
Old Apr 5, 2005 | 02:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote"> Just curious, but what octane are you running?</TD></TR></TABLE>
I have 2 programs, one on 91 and one on 112, both run fine.
Old Apr 5, 2005 | 04:14 PM
How different do the two maps perform, ie. which one has more power 'under the curve' ?
Old Apr 11, 2005 | 02:30 PM
wpgcivic's Avatar
yeah good call on the bad idle idiot, i know 2 people local running those cams and they both idle like stock!
Old Apr 11, 2005 | 02:39 PM
hype r 555's Avatar
Default Re: (wpgcivic)
Why would you run Stg 3's on 11.8 compression? Why wouldn't you go w/ stg 2's? I have 12.5:1 and stg 2's and am puttin down around 225whp....Just my 2 cents but what do I know
Old Apr 11, 2005 | 03:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah good call on the bad idle idiot, i know 2 people local running those cams and they both idle like stock!</TD></TR></TABLE>
Ok so maybe i was wrong about the idle, however, im 100% sure you will have more area under the curve (useable power) with 11.8:1 w/ the stage 2's or something equivalent.
Old Apr 11, 2005 | 08:22 PM
JBBNJ609's Avatar
p30 = jdm b16a2 (sir2) pistons (better then usdm pr3 pistons)
Old Apr 11, 2005 | 08:57 PM
johnzm's Avatar
Default Re: (lsed-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsed-eg &raquo;</TD></TR><TR><TD CLASS="quote">Why would you run Stg 3's on 11.8 compression? Why wouldn't you go w/ stg 2's? I have 12.5:1 and stg 2's and am puttin down around 225whp....Just my 2 cents but what do I know </TD></TR></TABLE>
skunk2 stg2 have a larger botto lobe than the stage3!!
means they wont idle as good
stage3 probably gets better gas mileage and rips harder into vtec.
u can move the same air as a 2 ltr@8000 if u rev a 1.8 to 9800
iMPoRT GeeK
Jul 29, 2007 12:32 AM
GSR_96814
Sep 19, 2006 01:44 PM
milton
Feb 3, 2006 08:01 PM
cs_x21
Jun 25, 2003 03:54 PM
