passwordjdm rear strut tower bar
ok i got em, no the rear i know i have to cut, but is there anyway to cut so that i don't have a massive gaping hole in the plastic?any help would be awesome! thanks
you could do something similar to what SurferX did for the JDM itr rear strut bar....the password bar is slightly larger, but using the same techniques he did, you can make it look clean.
thats not going to work for you bro... i just intalled the passwordJDM 4 point rear strut bar in my teg which is pretty much the same as the regular strut tower bar just a bit wider.... but you have to cut both the little plastic cap and the side pannel below it here is a pic off of passwordJDM
hope that helps ya... did my the same exact way looks clean in my opinion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 »</TD></TR><TR><TD CLASS="quote">is that an EDFC i see in there?</TD></TR></TABLE>
looks like a CD changer to me, bro. why would you put a damper-adjusting computer in the trunk? may as well get out and open the hood and trunk to adjust your dampers.
so, how does the bar feel? i was eyeballing that thing like a **** but it's expensive and i'm not sure it's worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 »</TD></TR><TR><TD CLASS="quote">sweet, and is that an EDFC i see in there? was it worth it?</TD></TR></TABLE>
thats a JL amp
thats a JL amp
thats is an edfc.... you guys are looking at two diff things the edfc is on the strut tower the amp is mounted on the back seat... thast not my car though those are pics off of passwordJDM.com.... i do have the bar in my car though and it does help and damn it looks sexy haha
I'm not sure exactly why the drivers side rear panel is higher than the passenger side rear panel but you do have to cut the little cover to make the password bar fit.
its a lil higher because it has to account for the line going to your gas tank... yea you have to cut the lil cover slightly on both sides i believe... maybe not on the drivers side... let me go look brb haha
