What fuel line do I need to use for this setup in my EG hatch?
I just swapped a Blox intake manifold onto my B18C in my eg hatch. The fuel line from the fuel filter will not reach the fuel rail. I think that I can use an Integra LS fuel line because it is supposed to be longer but not sure. So what has others done or used in this situation?
I did a little searching and saw that I may be able to to turn my fuel filter some and that helps. Im not currently near my car or I would try it.
Modified by ringgold at 8:15 PM 4/4/2005
Modified by ringgold at 10:26 PM 4/4/2005
Well i just tried a few things on the fuel line to make it work and it just isnt long enough to do anything with.
I just cut the stock fuel line in half in the middle and extended it with some fitting and some 5/16 hose. It looks fine and doesnt leak or anything
skunk2powered
Oct 17, 2005 04:01 PM
