any1 run into this prob with 2-1/2 carsound cat?
Old Jan 27, 2002 | 10:14 PM
infinkc's Avatar
Default any1 run into this prob with 2-1/2 carsound cat?
i installed my cat and jdm 4-1 header a few weeks ago, and ran into the problem that when the secondary o2 sensor is installed it hits the shiftlinkage. i just landed up putting a bolt in place of the o2. Running the stock jdm ecu anyway so the o2 doesnt matter.
Old Jan 27, 2002 | 10:31 PM
SMSP's Avatar
Default Re: any1 run into this prob with 2-1/2 carsound cat? (infinkc)
This is a very tight squeeze for the O2 sensor. The heat shield needs to be trimmed for the wires. You could try using some smaller diameter bolts in the 3 bolts flange and rotate the cat a trad, either way, to see if you can get the clearance needed.
Old Jan 27, 2002 | 11:26 PM
onyx00's Avatar
Default Re: any1 run into this prob with 2-1/2 carsound cat? (SMSP)
I had to trim my heat shield to make it work.
dylokjai
Nov 23, 2004 11:11 AM
Slow_Em1
May 9, 2004 05:09 PM
tachyteg
Mar 26, 2004 04:50 PM
Canuk_SiR
Jul 17, 2002 03:32 PM
