Vtec help
Old Apr 4, 2005 | 02:16 PM
NinjaTech's Avatar
Default Vtec help
Is there anything i can do to my engine to make my vtec way stronger without a swap?
Old Apr 4, 2005 | 02:18 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Vtec help (04civiclover)
Turn up your Flux Capacitor.
Also, check the muffler bearings. =P
Old Apr 4, 2005 | 02:20 PM
EJ6_Hatch's Avatar
Default Re: Vtec help (JDM_Ej)
your headlight fluid needs changed, oh and you could remove the gears for Reverse to save some weight.
NinjaTech's Avatar
how would i turn up my flex capacitor sorry im newb like a *****
Old Apr 4, 2005 | 02:25 PM
jlacoy82's Avatar
71.192.16.183
Wow, if you dont even know what a flux capacitor is, then your best bet is to start off by adjusting the womulator shaft for reduced bearing strain under load which should help unlock alot of power in vtec.
Old Apr 4, 2005 | 02:27 PM
NinjaTech's Avatar
Default Re: Vtec help (jlacoy82)
never heard of a womulator shaft
Old Apr 4, 2005 | 02:29 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 04civiclover &raquo;</TD></TR><TR><TD CLASS="quote">never heard of a womulator shaft </TD></TR></TABLE>
its right next to your vtec fluid resivor accumulator and dry sump system.
check the internal transducer for excessive shaft play.
Old Apr 4, 2005 | 02:30 PM
GTlvr82's Avatar
The man is a good sport...gotta give him that. You could feasibly put adjustable cam gears on the engine and take it to a dyno and tune it....I've seen it done...it helps a little...but not much...it won't make your (haha) vtec any better but it might improve your HP and TQ a tiny bit.
Old Apr 4, 2005 | 02:31 PM
NinjaTech's Avatar
Default Re: Vtec help (GTlvr82)
thx guys
Old Apr 4, 2005 | 02:34 PM
GTlvr82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 04civiclover &raquo;</TD></TR><TR><TD CLASS="quote">thx guys </TD></TR></TABLE>
His head is spinning...he thinks I am more than one guy....how many fingers am I holding up.... .!..
Old Apr 4, 2005 | 02:36 PM
jlacoy82's Avatar
71.192.16.183
Nononono, this was a big joke, we were all fooling on you.
If you seriously want to get a little more in vtec, try getting an adjustable cam gear (I assume you are rocking a d-series), and play with the cam timing a bit. Adjusting one way ( I believe retarding ) will give you a little more low-end torque and you'll lose a little up top. While on the other hand, by advancing ( Again, not sure, someone can confirm) will lose you a little power down low, but you should gain a very small increase up top.
Old Apr 4, 2005 | 02:45 PM
WildPig's Avatar
Wow you guys are frickin hilarious
It might not be good to mess with n00bs that much, next thing you know he's gonna come back posting that his vtec was TOO powerful and exploded his vtec soleniod resevior and got vtec fluid all over his wormulator shaft.
Old Apr 4, 2005 | 02:46 PM
GTlvr82's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Nononono, this was a big joke, we were all fooling on you.
If you seriously want to get a little more in vtec, try getting an adjustable cam gear (I assume you are rocking a d-series), and play with the cam timing a bit. Adjusting one way ( I believe retarding ) will give you a little more low-end torque and you'll lose a little up top. While on the other hand, by advancing ( Again, not sure, someone can confirm) will lose you a little power down low, but you should gain a very small increase up top.</TD></TR></TABLE>
I so already said this....jerk....
ben1284
46
Aug 20, 2012 11:05 PM
albertleee
20
Oct 31, 2007 06:18 PM
la_mente_maestra_13
Honda Civic (2001 - 2005)
23
Aug 29, 2007 07:31 PM
89_crx_sir
Aug 17, 2007 05:42 PM
skafia
Jan 13, 2004 07:10 AM
