o2 sensor
Old Apr 4, 2005 | 01:53 PM
sLoWrAcEr's Avatar
Default o2 sensor
i got a bosch universal o2 sensor for my hatch..i have a b16 swap and it has the 4 wire o2.....the bosch one has 2 black wires 1 grey and 1 white...i think the stock harness has a green.....does any one know know which ones to hook up? thanx
Old Apr 4, 2005 | 02:12 PM
sLoWrAcEr's Avatar
Default Re: o2 sensor (sLoWrAcEr)
anyone???
Old Apr 4, 2005 | 02:28 PM
sLoWrAcEr's Avatar
anyone off werk??!?!
Old Apr 4, 2005 | 02:31 PM
pdiggitydogg's Avatar
Pretty obvious that the grey goes to the green, dont you think?
Next time, search beforehand...this information is easily found
Relic1's Avatar
we need to know which harness you have, which ECU you have and what year/model the car is to give you the right colors to match up.
generally speaking...
2 black wires - heater
1 grey and 1 white - O2 signal
Old Apr 4, 2005 | 02:32 PM
sLoWrAcEr's Avatar
Default Re: (pdiggitydogg)
well do you just strip the wires and connect them? or do i have to use the stupid looking harness thing it came with?
Old Apr 4, 2005 | 02:33 PM
A smart person would cut the connector, w/ a few inches, of wire off the old sensor and connect the pos bosch unit to that. This way it will connect to the factory harness on the car.
sLoWrAcEr's Avatar
Default Re: (sLoWrAcEr)
stock 1993 civic si harness......im running the stock p28 or the gsr p72....seems to pull harder with the p28..im gettin it chipped soon.....1993 si hatch with b16
Old Apr 4, 2005 | 02:35 PM
sLoWrAcEr's Avatar
so just strip the wires connect them then cover it up with electric tape or get some fancy connectors?
use solder and, yes, tape too
Old Apr 4, 2005 | 02:37 PM
sLoWrAcEr's Avatar
do i have to solder or can i just use a smush connector thing......i am not good with wires and ****.....
Old Apr 4, 2005 | 02:38 PM
go ahead and use butt connectors
it doesnt matter because the sensor will foul out quickly anyway
Old Apr 4, 2005 | 02:41 PM
sLoWrAcEr's Avatar
why will it foul out quickly......i can have my friend solder it if it isnt going to foul out...i was just trying to take the quick route.....
accord2civic2prelude
Oct 11, 2010 07:29 PM
ReactioN
Sep 7, 2008 09:45 PM
95gainfla
13
May 7, 2007 09:01 AM
SI_Ro
Jan 12, 2004 06:43 AM
