plan to get 92-95 greddy turbo kit for $1450 shipped new. what else do i need for it?
getting greddy 92-95 turbo kit $1450 shipped. using it for a 98 civic ex coupe. what else do i need for it to run and bolt on my car? list of stuff to get with it would be very very very helpful. also prices (estimate)
THANKS!
THANKS!
Depending on what you have done to the car already you will probably only need a free flowing exhaust to help spool the turbo and allow it to breath better.The kit should include everything you need to run it safely.The only other thing the kit probably doesn't include is an intercooler (at that price).It's always a good idea to have one.
The pipes on mine. . .same set up you have. . . did not match up you will have to get 1-3 fabricated depedning on your IC.
it can be adapted to fit a gsr you have to drill the manifold and tap it your gSr head. buts it not highly sought after kit. The 92-95 ex kit is great for sohc cars. I would reccommed you get a ecplise side mount intercooler and fabricate a intercooler setup also. This will also help you benefit and gain more power. With this setup in 95 si hatch i ran 13.8 so tis possible to gain some massive gains for cheap.
92-95 ktis actually dont come with anything just piping lines and turbo and manifodl its very basic but does the job. you can weld a bov flange and get a type s greddy for cheap.
B18turbo - but if i really don't want massive hp, lets say i want a conservative boost to get my car to run 14.2's or so - do i really need an intercooler? do i have to really pay over 1000$ more for a kit designed for DOHC?
Keep in mind that the 1.6 SOHC Greddy kits dont come with injectors...You could however run it with your stock injectors...and true.no BOV for Greddy kits...or IC's..An eclipse or Starion/Conquest would be ideal...good luck.
THANKS!
THANKS!
well, i plan to get an intercooler with the kit as i know that helps the turbo out alot more than without. so then, after the install.....i still have to get someone to weld on the BOV and intercooler? can muffler welding shops do that?
Secret Squirrel
16
Jul 13, 2003 08:35 PM
