Which Shocks Will work?
Old Apr 4, 2005 | 11:19 AM
ramtyper19's Avatar
Default Which Shocks Will work?
Quick Question, Can the 96 - 00 Honda civic Coupe Shocks & Springs work on the 92 - 95 Civic Hatchback??
Just wondering if they are the same.
Thanks..
Old Apr 4, 2005 | 11:32 AM
ramtyper19's Avatar
Default Re: Which Shocks Will work? (ramtyper19)
Bump
Old Apr 4, 2005 | 11:43 AM
RARE_EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramtyper19 &raquo;</TD></TR><TR><TD CLASS="quote">Quick Question, Can the 96 - 00 Honda civic Coupe Shocks & Springs work on the 92 - 95 Civic Hatchback??
Thanks..</TD></TR></TABLE>yes..with minor mods
Modified by JDM_Del_Sol at 1:35 PM 4/4/2005
Old Apr 4, 2005 | 11:46 AM
Contraband's Avatar
NO!!!
Old Apr 4, 2005 | 11:47 AM
Contraband's Avatar
i take that back, the springs will but the struts wont.
Old Apr 4, 2005 | 11:51 AM
snatch's Avatar
Default Re: (LS95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS95eg &raquo;</TD></TR><TR><TD CLASS="quote">i take that back, the springs will but the struts wont.</TD></TR></TABLE>
If I remember right the only difference is the width of the LCA on the rear setup. One is a tad wider than the other, but it's nothing that can't be done. I've done it plenty of times. Works fine.
Old Apr 4, 2005 | 11:55 AM
b204dr's Avatar
the only probably swapping suspension i have had it when trying to use teg shocks on my ek- the rear lower part hit the lca and wouldnt sit right on the lca- not width problems - height problems with the fork portion of the shock- springs work fine tho
Old Apr 4, 2005 | 12:00 PM
EK k kay's Avatar
Default Re: (b204dr)
The forks on the rear struts of the 96-00 civic are not wide enough to fit around the 92-95 rear lca bushings. That's about the only problem.
Old Apr 4, 2005 | 07:04 PM
ramtyper19's Avatar
Default Re: (chowmien)
Thanks guys
hotxcivic92
Dec 24, 2007 06:31 PM
EvenStar
Suspension & Brakes
Nov 6, 2007 09:39 AM
Philip
Oct 21, 2005 08:59 PM
JforJonathan
Oct 7, 2003 12:01 AM
icechimpee
Sep 12, 2003 07:28 PM
