88 PGMFI accessing PCV tube at crankcase?
I disconnected the PCV Valve tube from the PCV Valve and cannot detect
any air flow so I think the tube may be blocked. Does this sound
reasonable?
I want to clean the tube by removing it and knocking any debris out of
it but I can't unfasten the tube from the crankcase. By sliding my
hand under the (I think they're called intake manifold branches) I can just
barely touch the fastener with a finger after I remove some other
tube/wire mounts. The fastener looks like a band of steal 3/8ths wide
and I can feel two prongs(one thin and one wide) on the underside of
the fastener about 1/4 inch apart.
Can someone please tell me how to access and remove this item?
thanks a lot
Eric
Also:
The valve sits on top imbedded in one of the intake manifold
branches so there is just 1 tube
from the valve to the engine and its very hard to reach.
PS: the valve itself looks like this,
http://img.eautopartscatalog.c...V.JPG
Oh yeah, I'm puffing smoke badly so trying to fix that before aircare.
thanks a lot
Eric
reasonable?
thanks a lot
Eric
Also:
thanks a lot
Eric
