d16z6 clutch in a 90 hatch?
Old Apr 4, 2005 | 11:05 AM
e jay one's Avatar
Default d16z6 clutch in a 90 hatch?
ok i just gave my buddie a used clutch kit off my d16z6 will it fit on his 90 hatch? it has a 4 speed tranny he just needs to get it moving again.
Old Apr 4, 2005 | 01:42 PM
Speed PHreak's Avatar
Default Re: d16z6 clutch in a 90 hatch? (e jay one)
Should work, just see if the clutch disc will spline up on the transmission. If it does you're good.
Old Apr 4, 2005 | 02:14 PM
Mach69's Avatar
you NEED to give us more information than that. We NEED to know what years the 4 speed is from. We dont need to know the year of the z6. If the 4 speed was an '89 then the 4 speed needs to use a z6 flywheel so the clutch can have the same contact area as the flywheel. I know on '88 si transmissions , the input shaft had a different number of splines than the '89 to '91 si transmissions, i do not know if that holds true for the 4 speed transmissions. (Someone verify this).
I am 75% sure that the Z6 had the same clutch diameter as the '90-'91 tranmissions. (verify this as well).
Old Apr 4, 2005 | 02:16 PM
EP3_05's Avatar
All 88 transmissions had the different number of input splines. All 90+ d series clutches have the same diameter.
Old Apr 4, 2005 | 02:35 PM
phatrick2332's Avatar
if your tranny is a 90 model year trans then the z6 clutch will work fine, as will the y8.
efking1985
Jan 27, 2007 12:34 PM
dkrex001
Oct 23, 2006 06:40 PM
tuname420
Aug 31, 2006 09:44 PM
EJ1 wilcox
10
Sep 9, 2005 08:06 AM
egchan
Oct 6, 2003 01:28 PM
