How do I open the rear light clusters to change a brake sidelight?
4th Gen.
Do I remove the two posidrive screws I can see?
4th Gen.
Pull the carpet back from inside the trunk. There should be three screws, the one towards the edge of the car is a bit of a pain but not bad. Pull the harness off, pull the plastic off and all the lights come out attached to the plastic.
the 2 screws are taken out to remove the white plastic light assembly from the back of the taillight.
The 3 small nuts that he made reference to above are taken out if you want to remove the entire lens off the car.
either way,
either way,
Legion
Apr 23, 2007 02:47 AM
TealCivic93
Aug 30, 2005 01:18 AM
