How much boost can a stock h22 handle?
Old Apr 3, 2005 | 11:07 PM
the_nautilus's Avatar
Default How much boost can a stock h22 handle?
I asked in a different discussion, but no one seemed to notice, so I'm asking again -- what kind of boost can the stock h22 handle, and what's the weakest link?
Old Apr 3, 2005 | 11:20 PM
PowerUser's Avatar
Default Re: How much boost can a stock h22 handle? (the_nautilus)
look up and to your right. SEARCHing is your best friend here. it's been covered so many times before it's not even funny.
quick search got some cool info:
https://honda-tech.com/zerothread?id=984472
need more help or info search around, there's alot more info here. all you need to do is ***search***
Old Apr 4, 2005 | 05:07 AM
i did search -- it said "no results" -- sorry i'm not so uh...thread inclined.
oh yeah - and the thread you sent me to didn't answer the question.
Old Apr 4, 2005 | 05:14 AM
SpeedMachine's Avatar
Default Re: (the_nautilus)
no you really didnt search....either that or your not searching correctly
the search engine is down right now but i assure it has been covered several times.
Old Apr 4, 2005 | 05:28 AM
pentaq's Avatar
Default Re: (SpeedMachine)
That's why it should be faq'ed and all such topics locked.
Old Apr 4, 2005 | 05:41 AM
92hondalude's Avatar
Default Re: (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">That's why it should be faq'ed and all such topics locked.</TD></TR></TABLE>
Old Apr 4, 2005 | 05:46 AM
v4lu3s's Avatar
RTFM
there is a thread that details a 15+ psi setup on a stock block..its even pretty recent.
Old Apr 4, 2005 | 06:08 AM
Drag_On's Avatar
Jesus, he cant find the answer - quit telling him to search..
H22s dont do well above 7 pounds with a larger sized turbo.. With smaller turbo - 10 psi is possible..
Its all about the tune. The ringlands crack with a hint of detonation.. 15psi is a FREAK motor and it WILL blow up..
Be safe
Old Apr 4, 2005 | 06:15 AM
RemerLex11's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">there is a thread that details a 15+ psi setup on a stock block..its even pretty recent.</TD></TR></TABLE>
hmmm got a link to that thread.......build your engine and you wont have to worry about it and you'll be much happier in the long run.
Old Apr 4, 2005 | 10:19 AM
T-King's Avatar
Default Re: (Matt5745767)
Yea but he said stock, like it was posted, I wouldnt go more then 7 or 8 lbs if you drive it every day. If you change pistons would could go a little more.
Old Apr 4, 2005 | 10:27 AM
Drag_On's Avatar
Default Re: (T-King)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-King &raquo;</TD></TR><TR><TD CLASS="quote">Yea but he said stock, like it was posted, I wouldnt go more then 7 or 8 lbs if you drive it every day. If you change pistons would could go a little more.</TD></TR></TABLE>
Cant do that either.. Pistons dont mix with FRM sleeves unless you use Mahle's which have a bad track record on fitment..
Its either FULL build or low boost.
Old Apr 4, 2005 | 12:20 PM
boosted lude's Avatar
Default Re: (Drag_On)
yup full build or low boost... my motor was tuned at 9psi on a t3/t04e turbo and lasted 10 months which included some 12-13psi runs as well...
Old Apr 4, 2005 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Jesus, he cant find the answer - quit telling him to search..</TD></TR></TABLE>
Praise Jesus, I found someone with a little sense!! I'm amazed so many people took the time to write back, telling me how dumb I am, when they knew the answer the whole time....and it would have been easier for the first guy to just answer the question, and move on. and yes -- i have used the 'search' function on many message boards before, and no - I still don't find crap on this in here. I appreciate your answer, Drag_on.
for the rest of you - do a search for 'stock boost' or 'stock turbo' in the prelude group and see what you find for yourself.
Anyways, this thread should be LOCKED. Question answered, it's over.
Old Apr 4, 2005 | 12:46 PM
GqchYnAbOy's Avatar
7psi and you should be fine...hopefully
Old Apr 4, 2005 | 12:56 PM
silver97prelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_nautilus &raquo;</TD></TR><TR><TD CLASS="quote">
do a search for 'stock boost' or 'stock turbo' in the prelude group and see what you find for yourself.</TD></TR></TABLE>
I did a simple search for 'stock boost' and 13 topics came up that all seemed to answer your question. My guess is you didnt choose the 'archive' radio button.
Try that and you will see plenty of results.
Old Apr 4, 2005 | 01:36 PM
another person with sense! Now that I know how to use the search function properly, I'm sure I'll bug you guys far less -- hell, you might not ever have to post again on this board But seriously, thanks silver.
-E
Old Apr 4, 2005 | 01:38 PM
Default Re: (boosted lude)
what blew in your motor after 10 months?
Old Apr 4, 2005 | 02:12 PM
Ataraxia's Avatar
Next time someone asks this question, we should all just assure him that it will easily handle 12 psi.
Old Apr 4, 2005 | 02:29 PM
SKDRCR's Avatar
Default Re: How much boost can a stock h22 handle? (Jonas427)
Like stated earlier, it's all about the tune.
There is a guy (Firedrake) who I believe has been running 14psi
over a year on stock internals, but you better have an awesome
tuner to achieve that yourself.
I'd stick with 8-9 psi and find a very good tuner if you want your
motor to last.
Good luck.
Old Apr 4, 2005 | 03:56 PM
ky_lude's Avatar
Default Re: How much boost can a stock h22 handle? (SKDRCR)
Damn thats amazing 14 psi? I'd run anywhere from 7-9psi for daily driving on stock internals. Anymore than that build the block.
Old Apr 4, 2005 | 10:15 PM
ringlands, melted a piston, hole in my water pump... thats about all...
Old Apr 4, 2005 | 10:23 PM
boostedlude97's Avatar
motor carnage!!!!! i love it
Old Apr 4, 2005 | 11:01 PM
damonk's Avatar
Default Re: (boostedlude97)
off topic, but i dont understand how you guys would pass smog in cali and if you have to convert to run obdII on a 5th gen
Old Apr 4, 2005 | 11:08 PM
bad-monkey's Avatar
Default Re: (damonk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by damonk &raquo;</TD></TR><TR><TD CLASS="quote">off topic, but i dont understand how you guys would pass smog in cali and if you have to convert to run obdII on a 5th gen</TD></TR></TABLE>
the key to passing smog in cali is lots and lots of grease.
Old Apr 4, 2005 | 11:11 PM
SoOHiGH's Avatar
you'll be amazed at how many places pass people with mods. I had cai, header, and check engine light on and still pass. just gotta slip him some money thats all .
btw If they see a CEL they are suppose to fail you right away.
